It is currently Sun Nov 15, 2026 12:33 am
Post new topic Reply to topic  [ 271 posts ]  Go to page 1, 2, 3, 4, 5 ... 19  Next
PostPosted: Tue Jun 14, 2016 2:32 pm
I am looking at a fuselage project that has the main wing attachment bolt holes already drilled in the fuselage bulkhead (that is under the pilots/passenger legs).
I have a set of wings that are completed. Is there a reasonable way I can mate these wings on this fuselage and account for the likely issue of the main wing attachment bolt holes not matching up perfectly?
PostPosted: Tue Jun 14, 2016 2:38 pm
I would remake the fuselage spar , Make a new spar and mate it to the wing, using the attach fittings, then install it in the fuselage. Duke and I just did one.
PostPosted: Sun Jun 19, 2016 7:25 am
Thanks Bill. I just bought it. :o
PostPosted: Fri Jun 24, 2016 12:25 pm
well, here she is. Now I want to mate the empennage and wings, and go make airplane noises...
PostPosted: Fri Jun 24, 2016 12:47 pm
Looking good Billy Ray ! One thing you might want to do is remove the "red" tape , especially if it is the really sticky stucco type tape . If you leave it on too long a lot of the adhesive will remain on the AC when it comes time to remove the tape . Then its a lot of goo be gone (water based only !) to get the funky stuff off . ??? Go ahead , ask me how I know . Go ahead ask me !! ::)
PostPosted: Fri Jun 24, 2016 2:59 pm
RB,
Just how do you know this stuff?????
inquiring minds want to know! >:D
PostPosted: Fri Jun 24, 2016 3:37 pm
S or T?
PostPosted: Fri Jun 24, 2016 5:52 pm
Its the T variety.
PostPosted: Fri Jun 24, 2016 8:09 pm
Bruce : My knowledge of the "Red Tape" came to me in a vision while moving the controls behind the curtain ! :P Actually from using the stuff for many years around the house , especially when using it to put up plastic sheeting to protect the house when pouring concrete . It was the only stuff that would stick to the stucco siding of the house and then the name..."Stucco Tape" was born ! 8) Yes , it is actually called stucco tape . ::) The holding power was so good I used it for other projects and when I left it on too long...well you know the rest of the story . You can find it at Home Depot in isle 7 , bin #11 . :o
PostPosted: Sat Jun 25, 2016 5:01 am
A note on drilling the spar bolts...I made an eight degree angle out of 1/4" x 2" angle iron overall length was about 3 feet. Clamped this to the spar and using a mill drilled the holes, repeat the other wing spar. This will give you the same dihederal both sides. It might be less or more than 8 but will be the same each side. I always say make the same mistake both sides and no one will ever noti
PostPosted: Sat Jun 25, 2016 7:06 am
that's a good tip Bill, thanks.
PostPosted: Thu Nov 24, 2016 4:49 pm
Got her home and on the gear (tailwheel is temporary). Happy Turkey Legs!
Pilotjk
PostPosted: Thu Nov 24, 2016 7:11 pm
Images: 5
Looks good looking forward to progress pictures of your project
John Letkeman
N2562K SN.922
Seminole Tx
(KGNC)
PostPosted: Thu Nov 24, 2016 9:19 pm
Looks like the partially completed project I bought back in 1984 ! :o One tip when you get ready to make the trim strips for the canopy and windshield , go to the 99 cent store and buy a bunch of the large poster boards (2 for 1.00) and use then to make your templates before you begin to cut the aluminum strips . You will be surprised how much aluminum you will use when it comes time to make them for real ! ???
PostPosted: Sun Jan 15, 2017 3:21 pm
I am trying to install the 602 Fittings that attaches to the fuselage at the 601 bulkhead (where the front main wings attach to the fuselage). The plans call for a NAS 177-6-5 Hi-Shear Rivet with a NAS 179-6 Collar to be installed in the top corner. Is there a suitable substitute everyone has been using here in place of the hi-shear rivet and collar? I have attached some pictures to (hopefully) make it clear what area I am discussing. In the second photo I am pointing to the rivet in question.
[ Time : 0.332s | 12 Queries | GZIP : On ]
