It is currently Sun Nov 15, 2026 12:58 am
Jim0258
 Post subject: Restoring N7077J
PostPosted: Sat Jul 15, 2017 10:00 pm
In March, I flew out to CA to pick up the airplane and trucked it back to Ohio. Cubes was a big help getting me some parts I needed to get the main gear on as well as a few other bits and pieces. I had a lot of work to do on the aft fuselage, but I think that's all behind me now (hehehe). I've been meaning to post some pictures for a while, and am finally getting around to it.
File comment: Replacement skin installed.
File comment: Found some cracks in the upper and lower flared flange. None went beyond the flange itself, but I'm betting they were caused by the lack of a bolster. I stopped drilled them and installed doublers.
File comment: Test fit on the air frame.
File comment: Made a new vertical fin with a fitting for a NAV antenna.
File comment: Made a new skin with access panels.
File comment: I cut the flange off and made repairs.
File comment: Now, this was a problem ...
File comment: Customized the bolster support. The stock part would not fit, and I wanted to distribute the load a little more evenly between the BHs.
File comment: Main Gear On
File comment: Back in Ohio
File comment: Loading up the truck
N7077J
I-68
 Post subject: Re: Restoring N7077J
PostPosted: Sat Jul 15, 2017 11:42 pm
Nice looking metal work ! ;)
PostPosted: Sun Jul 16, 2017 12:59 am
Wow that was a lot of work. That part you designed looks really nice. I'm glad it's coming together.
TonyNZ
PostPosted: Sun Jul 16, 2017 3:46 am
Images: 8
Great work. Boy there are some good restorations taking place! :)
Tony
ZK-VMS
T18C
Jim0258
PostPosted: Sun Jul 16, 2017 8:00 am
Thanks! I've been getting lots of practice over the last 5 years working on a Midget Mustang Project.
N7077J
I-68
PostPosted: Wed Oct 17, 2018 11:38 am
Jim,
How is your project coming? Where are you in Ohio?
John
[ Time : 1.078s | 11 Queries | GZIP : On ]
