It is currently Sun Nov 15, 2026 1:30 am
flychris
PostPosted: Thu Mar 15, 2012 7:35 pm
About to do the W&B I have no plans. I'm guessing you weigh it with the tail up like in flight?
Chris
PostPosted: Thu Mar 15, 2012 7:42 pm
You are correct. Check Tony Benglis and his process for weighing A/C. Do you have a set of scales ? I found a place that rents a set of "certified" A/C scales at the local airport for $35.00/day. A steal !
PostPosted: Thu Mar 15, 2012 8:38 pm
Put the level on the reinforcing strip on the fuselage side. Then level across the canopy tracks at the seat back.
That will put the plane in the proper attitude for the job. WARNING! The tail is real high and very light on the tail wheel. Don't let it tip over! You will find over 400+ pounds on each of the mains. A bathroom scale won't cut it.
flychris
PostPosted: Thu Mar 15, 2012 8:56 pm
Thanks for the reply! I have cert scales as I'm a full mtc shop. Just wanted to take the head scratching out of this lol
Chris
PostPosted: Thu Mar 15, 2012 9:57 pm
I wish I had more head scratching than butt scratching !
PostPosted: Fri Mar 16, 2012 7:26 pm
you need to get that checked :))
PostPosted: Fri Mar 16, 2012 7:35 pm
I will during the next annual !
[ Time : 0.208s | 10 Queries | GZIP : On ]
