It is currently Wed Nov 11, 2026 12:27 pm
 Post subject: IO-360-BIA
PostPosted: Wed Aug 17, 2011 10:11 am
Will an IO-360-BIA fit in the standard T-18 engine compartment? A friend has one he may sell to me but I dont want it if it wont fit. Anyone have any insight?
Ryan
PostPosted: Wed Aug 17, 2011 10:18 am
If it's an angle valve, your cheeks will need to be squirreled as the standard cheek will not fit over the valve covers.
PostPosted: Wed Aug 17, 2011 6:24 pm
I was afraid of that. Thanks Frasier.
PostPosted: Wed Aug 17, 2011 6:33 pm
The angle valve engine is significantly heavier so by the time you put the necessary weight in the tail for proper weight and balance, you will not gain anything.
PostPosted: Wed Aug 17, 2011 8:05 pm
B1A is an injected parallel valve motor, should be fine.
PostPosted: Thu Aug 18, 2011 8:17 am
I guess I should just go measure the thing and be done with it. I appreciate all the info.
[ Time : 0.173s | 11 Queries | GZIP : On ]
