It is currently Mon Nov 23, 2026 10:38 pm
Post new topic Reply to topic  [ 271 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19  Next
PostPosted: Sat Oct 08, 2022 1:49 pm
Here is my issue. Just not any room under that carb. there is about 1 inch clearance at the lowest point. Any suggestions on best path forward?
Image Image
PostPosted: Sat Oct 08, 2022 8:35 pm
Most guys with carbs use some type of intake scoop to make room.
PostPosted: Sat Oct 08, 2022 10:48 pm
Ryan, my "banjo" air box has about 1" of clearance from the carb to the bottom of the air box. Reference photos above, the last one show the bowl around the carb, according to -782 it is 3" deep, the air box -781 is also 3" deep. My engine seems to breath just fine, the filter is 11" dia x 3" deep.
It looks like if you want more than 1" clearance that there is some fiber glass work on the horizon. 8)
PostPosted: Sun Oct 09, 2022 8:48 am
Yep, I think you're right Bruce. I just have to make myself cut that fiberglass. I really didn't want to do that. This cowl does have the scoop attached already, so that's why I'm a little surprised at the way its all fitting together.
PostPosted: Sun Oct 09, 2022 2:37 pm
Ryan : Hard to tell from your pics , but my glass scoop appears to be deeper than yours ? I got mine from Mike Archer many years ago and it was actually a two piece part...the scoop and the lower cowl . You had to off set the scoop slightly to fit the carb/filter/carb heat box . Even then it is a tight fit on the sides to get the carb assembly to fit . Eleven years later no problems noted .
PostPosted: Mon Oct 10, 2022 9:26 am
Thanks Rich, lowering the scoop is another option I hadn't considered. That may be a solution.
PostPosted: Mon Oct 10, 2022 9:09 pm
Remember...I am always right at least 50% of the time !
 Post subject: Alumimun Carb box?
PostPosted: Mon Aug 18, 2025 7:03 am
Is there any reason I should not build a custom carburetor air box out of 2024 aluminum? If thats not a good material choice, what should be used?
PostPosted: Mon Aug 18, 2025 11:48 pm
That will work as long as it is T351 type. You want to avoid any T6 temper with that application.
PostPosted: Tue Aug 19, 2025 6:34 am
perfect, thanks cubes.
PostPosted: Wed Oct 01, 2025 4:43 pm
Couple of progress pics. Since I built the shop with A/C progress has been really moving!
Image Image Image
PostPosted: Sun Oct 05, 2025 10:52 pm
Nice!
PostPosted: Tue Oct 07, 2025 11:55 am
O0 "Looking good Billy Ray !"
NX115RX
PostPosted: Sat Nov 01, 2025 3:07 pm
So the wing attachment angles are protruding below the wing, and when I go to install the wing gap covers, it does not sit flush as you can see from the pic. Should I shave off the protruding portion of the wing attachment fitting, or finesse the wing gap cover to where it will dip down below the protruding attachment?
PostPosted: Sat Nov 01, 2025 10:42 pm
Roll a longitudinal "V" into the strip.
[ Time : 0.273s | 12 Queries | GZIP : On ]
