It is currently Tue Nov 10, 2026 4:18 pm
peterjaypriest
PostPosted: Wed Jun 15, 2022 6:06 pm
To anyone that has installed a Garmin G3X autopilot (with GSA 28 servos,) I am seeking input...
A few months ago, I installed a G3X system, with the Garmin autopilot (GSA 28 servos) coupled to a Garmin GPS175 navigator. I now have about 35 hours on the airplane post-install, and use the autopilot on every flight.
The autopilot works well, mostly. The Heading / Roll / NAV portion is perfect. The pitch works fairly well, but not perfect. In altitude hold mode, the plane will, after a few seconds, begin to hunt about 25 - 50' ( + -) from the altitude set in the window. Then it might settle down at the correct altitude for a few seconds, and then start wandering again. The autopilot is not coupled to any trim servo.
I've spent quite a bit of time going through the Autopilot Tuning steps outlined by Garmin. I've bracketed the gain settings trying to narrow down what works best, and have it optimized, I think, but the hunting continues.
If you've installed one of these systems, and the altitude hold (and VS mode, IAS mode) work well for you, could you share the various gain settings for your elevator servo?
Thanks a lot,
Peter
peterjaypriest
PostPosted: Wed Jun 22, 2022 10:18 am
Thanks for the reply, Bruce.
The roll servo works very well- zero problems, smooth and precise navigation. Although I've yet to do any approaches with it, I think it will work fine.
But the pitch is still hunting a bit. If I set it to vertical speed = 0, or altitude hold mode, is will gently porpoise to either side of the set altitude. It's tolerable if I'm not looking at the vsi or the altitude tapes. The pitch change is subtle. But I can hand fly it better than that, so I'm sure the autopilot is not quite right.
I've spent hours adjusting the gain settings and thought they were pretty well optimized- yet the hunting continues. After seeing a YouTube video of a Mooney with the exact same behavior (that guy replaced the servo which fixed his problem, I swapped in another servo. That didn't change things. I mounted a camera in the back to see where the crank arm was in relation to the pushrod in level cruise flight. That all looks good.
I've now reached out to G3X Expert at Garmin, and they suggest it is the vertical gain setting. I'd be very interested to learn what your pitch gain settings are. In the meantime, I'll fly more and work on it.
Thanks again,
Peter
PostPosted: Wed Jun 22, 2022 8:36 pm
It sounds like static lag to me. I recently helped a friend with a Bendix/ Trutrack system and the static line was either too long or it had other instruments hooked up to it. A separate line fixed it.
Regards,
peterjaypriest
PostPosted: Wed Jun 22, 2022 11:29 pm
Thanks Jim.
The static port / line has been in my mind after reading other's reports. But I'm not sure what I can do, other than ensure there are no leaks. I have a Piper style pitot / static mast on the port wing. That is all plumbed into the G3X ADAHRS (GSU 25.) So, straight from the static source to the GSU 25. There appear to be no issues with ADS-B reporting, etc....
When you say, "A separate line fixed it." Can you elaborate on that a bit?
Thanks again,
Peter
PostPosted: Fri Jun 24, 2022 11:30 am
Peter,
Basically you want to reduce the volume of air in the static system to a minimum. Since the air is compressible it acts like a spring and the static air pressure will fluctuate a bit and the A/P sees this. This results in the oscillation you are seeing. In the case I worked on we reduced the size of the tubing and tee'd in a separate line at the static source. Maybe you could try another static source with a shorter line length.
regards,
peterjaypriest
PostPosted: Fri Jun 24, 2022 4:35 pm
Thank you, Jim. Your explanation makes perfect sense.
I think I will dig into the static system, as I'm exhausting the other possibilities. The gain settings definitely have an effect, but at best, I can only minimize the oscillations. I can't seem to eliminate them.
I'll report back after checking / sorting the static system, etc.
Thanks again,
Peter
peterjaypriest
PostPosted: Sun Jun 26, 2022 4:14 pm
Big thanks to Jim for suggesting the static line as a potential problem!
I disconnected the static line and flew for about 45 minutes (mostly in a holding pattern.) With the static line disconnected, the altitude hold was perfect!
But of course, that affects the indicated airspeed and altitude, so I'll have to figure out the static solution. Not sure if the Piper mast (which is a combination pitot and static port) might be causing the problem. Or, as Jim suggested, reducing the diameter / length (volume) of the static line might work to resolve the hunting.
I guess I can cut holes in the fuselage sides for static ports, if necessary. I'd prefer not to do that....
But in any case, I'm happy to be making progress, at last!
Pete
PostPosted: Mon Jun 27, 2022 10:45 am
I have to use a combination of Piper blade input and cabin air static to make all my stuff work.
peterjaypriest
PostPosted: Mon Jun 27, 2022 12:47 pm
That's interesting, Bob.
In my case, the only static connection I have is to the GSU 25 (ADAHRS.) So, I can use cabin pressure as the static source and the altitude hold will work great. But the altimeter, transponder, and
ADS-B I guess will be off.
I've reached out to Garmin (G3Xpert) to see if they have some advice. And I'll get ready to replace the static line with something smaller in diameter. Maybe some 1/8" nylaflow...
Peter
PostPosted: Tue Jun 28, 2022 2:13 pm
My Settings ... I have zero complaints
peterjaypriest
PostPosted: Tue Jun 28, 2022 5:58 pm
Thanks a lot, Lee! Your settings appear to be near the defaults- which are about where mine are now. (after exploring a huge range!) I think there's another page of settings- for Vertical Speed gain and Airspeed Gain- but I have the older Legacy G3x (non touch) so maybe yours doesn't have those. In any case...
My issue is definitely related to the static source on my airplane- I had erroneously thought it was a gain setting that needed tweaking. (Garmin's suggestion.)
With just cabin air as the static source, my autopilot works perfectly. Zero hunting. The roll / nav tracking portion has always been perfect. I've sent the G3X logs for the "perfect" flight to Garmin, and will see what they have to say.
So, just have to figure out the next step, which may be to add static ports to the fuselage sides, and use the existing Piper pitot / static mast for pitot only.
Thanks again,
Peter
PostPosted: Wed Jun 29, 2022 7:17 pm
Use caution when putting static ports on the sides of the fuselage. The side venting Thorp cowling may disrupt the air you are sampling.
peterjaypriest
PostPosted: Wed Jun 29, 2022 8:42 pm
Thanks for the heads-up, Bob. I've seen that warning elsewhere in the forum.
I'll only add the static ports to the fuselage sides as a last resort. I'm still waiting to hear back from Garmin after sending them the flight log data...
Thanks again,
Peter
peterjaypriest
PostPosted: Wed Jun 29, 2022 8:45 pm
Lee,
Where does your GSU 25 ADAHRS get it's static source? Do you have static ports on the side of the fuselage? Or are you using a Piper pitot / static mast? Something else?
Peter
PostPosted: Thu Jun 30, 2022 9:38 am
I do have a Piper pitot that I (briefly) pulled my static source from. After one flight using it I disconnected the hose and used cabin air (speeds were skewed low). All of my static air comes from a single source now, under the LH seat.
[ Time : 0.211s | 10 Queries | GZIP : On ]
