It is currently Mon Sep 28, 2026 10:25 am
 Post subject: Wing Tips
PostPosted: Sun May 31, 2020 9:08 am
This is off a Grumman Cheetah/Tiger. Might have some clues as to Hoerner profile.
 Post subject: Re: Wing Tips
PostPosted: Sun May 31, 2020 2:10 pm
Ah, I see the difference now in what I have. Thanks for posting
hjubm2
PostPosted: Sun Jun 14, 2020 11:43 pm
Has anyone built the Hoerner tips out of fiberglass? And if so how hard is the process? My tips are 40+ years old and the fiberglass is going bad so it might be time to replace the original tips with a new style.
PostPosted: Mon Jun 15, 2020 8:04 am
Paul McMicheal in Seattle built a pair quite recently and he raved about the performance improvement.
There is a good article in one of the newsletters describing how to build them. It may have been written by John Evans, but I’m not sure.
PostPosted: Mon Jun 15, 2020 9:15 am
I would be all over buying a set of Hoerner wing tips if anyone has a set. As far as me building them, that's too much for my current fiberglass skill level.
PostPosted: Mon Jun 15, 2020 10:17 am
Cubes sells them .. there's also a great 'how to' out there ... I can probably track down the exact newsletter. If I had to guess it's in the '90s era.
PostPosted: Mon Jun 15, 2020 11:46 am
Didn't, think of Thorp Central. Well, I guess they will get some more of my money.
PostPosted: Mon Jun 15, 2020 4:29 pm
Don’t hesitate to spend money at Thorp Central!!!! We need TC to stay in business.
PostPosted: Mon Jun 15, 2020 11:30 pm
Our Hoerner tips are in the S18 profile. They would make a great start for someone who wanted them on a T18. All you would have to do is cut the splice about 1/3 of the way back, pull them down to the T18 profile, and reglass them.
For the T18, we stock the original profile tips.
PostPosted: Tue Jun 16, 2020 6:16 pm
Tried to upload John Evens article but failed (maybe too big)
Author date was Sept. 2003 if it helps.
PostPosted: Tue Jun 16, 2020 6:39 pm
Here's a drop box link
https://www.dropbox.com/sh/o403ydna8v66 ... r6_Za?dl=0
pmandel
PostPosted: Wed Jun 17, 2020 8:15 am
Forgive my ignorance, but advantages of Hoerner on the T-18 are...?? According to https://www.aircraftspruce.com/catalog/ ... ngtips.php which is for C-150/172/etc:
Typical Improvements are:
• Increase cruise 3-6 mph
• Increase rate of climb 75-100 ft./min.
• Increase stability with more positive aileron control
• Decrease stall speed 4-5 mph
• Decrease distance for take-off
• Gives a modern, more aerodynamic profile
And according to https://www.eaa.org/eaa/news-and-public ... troduction --
"The result is a 5 percent improvement in cruise speed." (at least on a Sonerai, obviously much slower than our birds)
Does anyone have actual numbers/advantages -- meaning measured, real world, not theory -- for the T-18? Please convince me that I want them. Very intriguing!
(PS: My A&P would do all the modifying ("cut the splice about 1/3 of the way back, pull them down to the T18 profile, and reglass them"), fitting, painting, etc. I have zero ability in that regard, but he does.)
Philip Mandel
N118BC
S/N 957
Beaverton OR
PostPosted: Wed Jun 17, 2020 11:55 am
FWIW - here is a portion of an email I recently sent to a couple of other Thorp owners...
"There was no particular subjectivity in my testing of their performance. As I reported at the time I actually flew with one of the new and one of the original tips, with the new one on the left wing - the wing that normally was "heavy" with just me onboard, requiring a bit of the original roll trim (slightly lowering the position of that flap). Not only did I not need the trim, but I had to hold a considerable amount of left aileron pressure to compensate for what was obviously greater lift. It was surprising, right from lift-off, but increased as speed increased. Then I installed the other one and it was nicely balanced again. It's a little surprising and I have no explanation for it, but I saw no discernible difference in my full-throttle top speed - approximately 204 mph TAS at 7500' MSL. The biggest difference in handling was then during landing & especially when getting into ground effect... that extra lift was very obvious and I grew to like it a lot. I ended up lowering my approach/landing speeds quite a bit... seriously, about 10 mph.
Richard Eklund had a friend who was quite a good metal-worker - I don't recall his name, but you probably know who I'm talking about. He & Richard carefully studied and took careful measurements of my tips one year at OSH. He then proceeded to build a set out of metal. They were very well done and matched the fiberglass ones pretty closely, except for a more rounded outer edge. He sold that first set to my best friend and hangar-mate, Dean Cochran. Dean put just one on at first, and performed the same test that I had. He actually took a spring scale up with him and measured the force needed to hold that wing down & level. I don't recall what it was but it was considerable, and he documented it in the newsletters I believe. Richard's friend later built a second set for Richard's airplane, and he confirmed similar results."
I had enough Thorp time with the original design tips at the time to be able to make a good comparison of the new ones with my airplane. I can't attribute all of the decreased landing speed to the new tips, but they definitely made a very noticeable difference for me, making the landings more comfortable at those speeds. The level WOT speed referenced may have varied a couple of MPH one way or the other, but 204 is very close, with or without the "new" tips. 160 hp O-320-D2A and Aymar-Demuth prop.
pmandel
PostPosted: Fri Jun 19, 2020 10:35 am
That is seriously cool info, John. Thank you.
Philip Mandel
N118BC
S/N 957
Beaverton OR
PostPosted: Fri Jun 19, 2020 8:06 pm
There is a series of videos on YouTube showing how to build Hoerner tips.... similar methods as what is described in the Newsletter article.
https://m.youtube.com/watch?v=sDHynvw9Ozo
https://m.youtube.com/watch?v=RoOh-fgI8oU
https://m.youtube.com/watch?v=ULhZchv7ito
[ Time : 0.124s | 10 Queries | GZIP : On ]
