It is currently Mon Nov 23, 2026 10:15 pm
Post new topic Reply to topic  [ 271 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 19  Next
PostPosted: Thu Apr 02, 2020 12:36 pm
Usher makes good products. Just mount it so that you will drain it before each flight and can easily remove it for inspection at annual time. Gascolators that are hard to get to often do not get used.
PostPosted: Thu Apr 02, 2020 2:40 pm
Perfect, thank you.
PostPosted: Thu Apr 02, 2020 4:21 pm
Mounted my usher to the firewall using (2) standoffs to give me room to remove the sediment bowl . It has been on for 10 years with no problems . Recommend you have a couple of sediment filters and Viton o-rings on hand . Cheap parts and there when you need them for annuals .
PostPosted: Thu Apr 02, 2020 4:24 pm
Hey Rich, if you get really bored during the COVID19 lock-in, I would love to see some photos of how you mounted your Usher gascolator. I've copied most everything else from you, why not my gascolator mount too.
PostPosted: Thu Apr 02, 2020 5:01 pm
I'll give it a try ! ??? Won't make it to the airport until Sat/Sun . Will see what I can do ? I went to the double aught spy class taught by Jethro Bodine and graduated with a D - in photo makin ! :P
PostPosted: Sat Apr 04, 2020 3:02 pm
Dude: Best I could do with the bottom cowl in place . One week earlier and I would have had a clear shot during the annual with the cowl off . Nothing fancy about the mounting...except it was installed during the build with the fuel tank not in place and a clear firewall for mounting . No problems with the unit after 10 years in place .
PostPosted: Sat Apr 04, 2020 5:23 pm
oh, that's perfect shot Rich, many thanks.
PostPosted: Sat Apr 04, 2020 5:50 pm
Go to my personal album and there are (2) additional pics showing the gascolator during the build process w/o the (2) standoffs which were added later .
PostPosted: Mon Apr 13, 2020 10:39 am
Getting ready to install my fuel tank (DWG 528). Plans call out for rubber and cork to be cemented to the airframe. 2 questions:
1. What is the preferred method to attach the cork/rubber to the airframe...ie do you use cement, proseal, etc??
2. Does the rubber or cork get attached to the airframe first?
PostPosted: Mon Apr 13, 2020 11:57 am
Hi Ryan,
FWIW, I used contact cement. Yes, it does get glued/attached to the tank support structure & straps first. If you’re asking if it’s glued to the tank also, I would say no.
PostPosted: Mon Apr 13, 2020 12:37 pm
Thanks John. I'm also trying to understand if the cork is cemented to the airframe and then the rubber is cemented onto the cork, or vice versa? I can't tell from the plans.
PostPosted: Mon Apr 13, 2020 1:06 pm
IMHO, cork then rubber. Rubber makes contact with the tank.
PostPosted: Mon Apr 13, 2020 1:10 pm
Perfect, that's what I needed. Thank you both.
 Post subject: I need Fuel tank advice
PostPosted: Wed Apr 22, 2020 10:11 am
I installed my fuel tank and the sides of the tank are in contact with the longerons up near the firewall. What should I do about that?
PostPosted: Wed Apr 22, 2020 11:43 am
Aluminum tank? Massage with a hammer.
[ Time : 0.310s | 12 Queries | GZIP : On ]
