It is currently Tue Oct 06, 2026 4:23 pm
 Post subject: N18TE $22,000
PostPosted: Thu Jul 30, 2015 2:02 pm
I've listed my T-18 on Barnstormers for $22,000.
I haven't been flying it enough after I completed my RV-8.
It needs a new home where it can be flown regularly, and continue to receive care and that personal touch.
I've upgraded or renewed a few items:
Dynon D10a EFIS
replaced one mag with a Pmag
Upgraded to a Trusty Tail Spring with Flyboy's Eagle tail wheel.
Skytec lightweight starter
Crow cam release seat harnesses
David Clark ISOcom
Garmin GPS antenna
Replaced the engine driven fuel pump last year (just because I thought it was time to do it)
New brake pads
A pull from my ad:
Standard model T-18, 416 TT airframe & SMOH on O-290G conversion W/ o-320 crank & rods, sump & MA4 carb. O-435 cylinders. One P-mag. Vacuum pump. Electric & mechanical fuel pumps. Dynon D-10a EFIS, Narco Com 810 TSO, Narco AT-150 transponder, David Clark ISOCOM. Garmin GPS antenna and mount for 295. Recent Tires & brakes relined at last condition inspection. Ted Hendrickson 68x68 wood 2 blade prop. Crow cam operated harnesses. This is a good flying T-18 that has a good combination of take off and climb performance and good top speed. Fun 2 fly, easy to maintain best bang for the buck.
Youngbloodn480yscp
 Post subject: Re: N18TE $22,000
PostPosted: Fri Aug 18, 2017 1:35 pm
Do you have any pictures of the airplane?
PostPosted: Fri Aug 18, 2017 8:30 pm
Scott : Does this mean you are going to the dark side ? ??? Obeone will not be happy !! :P
PostPosted: Fri Aug 18, 2017 11:04 pm
RB;
I posted that over 2 years ago!
That plane bit me the day before flying out for Sedona 2016.
I'm slowly setting it straight, plus improving - lightening - simplifying it.
I have so many good T-18 friends, I'm keeping it.
I just reconnected the cabin heat control cable and reconfigured the oil filter mount Again
PostPosted: Fri Aug 18, 2017 11:15 pm
DOH !! :P I'll pay more attention to the date/time group before I express my humble opinion ! ::)
Youngbloodn480yscp
PostPosted: Sat Aug 19, 2017 9:48 pm
Not Scott his oldest son logan I'm looking to save up for a thorp since my dad said he'll never build another rich
Users browsing this forum: No registered users and 27 guests
[ Time : 0.304s | 10 Queries | GZIP : On ]
