It is currently Tue Nov 10, 2026 4:32 pm
 Post subject: ADSb
PostPosted: Tue Jun 13, 2017 9:28 am
I'm probably late to the party- but I was talking to another friend and the discussion turned to ADSb. I told him I had been waiting for Navworx to iron out their issues. He suggested looking at The echo UAT package. It available with a gps WAAS source or stand only if you already have a panel mount GPS on board.
Some Vans guys already have this installed with many positive stories.
Terry
218TH
 Post subject: Re: ADSb
PostPosted: Tue Jun 13, 2017 9:51 am
I was leaning toward NAVWORX , but to this point they have gone NORDO and haven't heard a word from them on any updates/FAA AD status . I ran across the UAVIONIX Echo UAT and this is one compact little unit . Reads the transponder via WiFi and no need to connect anything to the transponder/antenna cable . From what I can gather all you need is a power and a ground and you're in business . It is incredibly small and can mount almost anywhere and the price is in the ball park . Plan to keep an eye on this gizmo and if the FAA sharks don't take a bite out of it I'll probably pull the trigger and install this next annual . ;)
PostPosted: Tue Jun 13, 2017 3:33 pm
The uAvionix units are what I'm using on my new project. Amazingly compact, light & powerful for such tiny boxes. The ECHO UAT transceiver is dual freq. in and a full 20 watt transmitter (out). It has built-in wi-fi (the antenna is built into the box) to send weather & traffic data to my iPad & my iFly 740, as well as providing a link to an Apple or Android app for set-up, updates, etc. If you have a glass panel, it plays well with most of them I believe. It receives & processes data directly from your transponder transmission signal - no antenna cable clamp-on device needed. If you have a newer transponder with an RS232 output (like a Garmin GTX 327), you can wire it directly to that instead. These guys have been into the UAV/UAS market for awhile, where everything has to be as small, lightweight & powerful as possible. It seems like a very well-run company (they also build some of this equipment for Dynon). Since I didn't have a WAAS certified GPS source, I went with their SkyFX GPS unit which is in exactly the same size package as the ECHO. It comes with a small GPS antenna that I am mounting under the fiberglass glare shield. The ECHO comes with wiring harnesses & the UAT antenna. Those 2 antennas are all that is needed - the ECHO unit broadcasts & receives everything through that one UAT antenna. I bought the 2 units together for a $100 savings at $1399.
PostPosted: Tue Jun 13, 2017 11:07 pm
I like it ! Nice set up John . ;) Looks like I'll be busy next April during the annual . :P
rhartmaier
PostPosted: Thu Jun 15, 2017 6:13 pm
Is the UAVIONIX system approved for certified aircraft? Bob H.
rhartmaier
PostPosted: Thu Jun 15, 2017 6:26 pm
It doesn't look like it at this time , however it appears they are working on that . ??? I would go to their web site and follow their progress . I just signed up for their News Letter . 8)
PostPosted: Thu Jun 15, 2017 11:04 pm
The Navworx AD was published June 6, AD 2017-11-11 http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgad.nsf/0/3156ea8fd766278486258137004ff683/$FILE/2017-11-11.pdf and Navworx has some info on their web site for upgrading existing boxes except for the EXP box. That said the current price of their EXP box is $1599 and that does not include antennas or the device to read older transponder signals. I think that if I were going to do an install today I would be looking at the uAvionix box. NOTE: I have a Navworx ADS600-EXP box installed so I'm going to figure out how to comply with the AD.
PostPosted: Sat Jun 24, 2017 12:30 pm
Pulled the trigger and bought the UAvionix ADS-B Echo-UAT/SKY-EXT system . Was going to get the NAVWORX unit , but they have been pretty quite after the FAA kicked them in the rear end with an AD . :o Besides the UAvionix unit can do the transponder thing w/o a hookup to the x-pndr (WiFi) . $1399 , no tax and free shipping from iFLY GPS . I did attend an FAA TRACON brief about a week ago and according to the FAA at SOCAL they are not even geared up/or using the ADS-B system at this point in time at their facility ? ::) That is all .
PostPosted: Sat Jun 24, 2017 5:09 pm
I have been thinking about pulling the trigger on the Echo UAT as well. Can anyone please explain to a Wifi moron (me) how an old school transponder talks to the Echo UAT box via Wifi? I have a Microair transponder, and they say on their website that Microair is compatible with the Echo UAT, but I dont understand how they talk....I would think in order to talk via Wifi, each unit needs some kind of Wifi hardware or software inside each box.
PostPosted: Sat Jun 24, 2017 6:17 pm
Not exactly sure how the WiFi works ? ??? Not sure how my iFLY 720 GPS is able to use WiFi , but it does . I only have a Liberal Arts degree . :P I called UAvionix before I bought and explained what equipment I had (Microair ModeC/S x-pndr and a iFLY 720 GPS ) and they said it will all work with the ADS-B equipment they have . ::) If you have any doubts if your equipment will work with the UAvionix ADS-B give them a call ! ;) If these companies keep making this equipment smaller I can probably have it installed the next time I have a colonoscopy ! :)
PostPosted: Sat Jun 24, 2017 8:24 pm
well, that is good news, because I too have the Microair xpnder and an IFLY 740.
PostPosted: Sat Jun 24, 2017 11:13 pm
The ECHO UAT doesn't transmit or receive anything to/from the transponder via WiFi. It receives everything directly from the transponder & signals from other aircraft transponders and through it's UAT antenna, along with receiving and transmitting the UAT data to/from ground-based systems. If you have an RS232 output from your transponder, or EFIS, you can also wire directly to that. The WiFi feature is for sending traffic & weather data directly to a portable GPS unit like iFly as well as to an iPad or Android tablet. It also allows you to connect with a tablet or smart phone for software updates, setup, etc.
PostPosted: Sun Jun 25, 2017 7:16 am
Ah, I get it now. Thanks John.
PostPosted: Mon Jul 03, 2017 5:27 pm
Went ahead and got the UAvionix ADS-B unit . Decided on the Echo UAT/SKYFYX-EXT unit . The SKYFYX part of the set up has the GPS receiver/antenna in one unit and only requires tapping into the Echo +/- power leads along with attaching the gray data wire to the Echo wire harness . Comes with attaching hardware . The 978 antenna needs to be mounted and you supply the coax from the antenna to the Echo unit . Attach the power/grd to the Echo unit via a 1 amp CB , program your GPS (iFLY in my case) to accept the data and UR in business . Incredibly light weight ! ??? I hate waiting until the last minute only to find this and other more expensive ADS-B units are on back order ! :o
[ Time : 0.268s | 12 Queries | GZIP : On ]
