It is currently Sun Nov 08, 2026 2:11 pm
Post new topic Reply to topic  [ 273 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 19  Next
PostPosted: Sat Jun 10, 2017 6:57 pm
Yep, castellated nuts and "cotter" pins (Rich, I not familiar with a carter pin....is this high vibration area--check AC43
PostPosted: Sat Jun 10, 2017 7:27 pm
You know Carter's got pills ! ???
PostPosted: Sat Jun 10, 2017 9:08 pm
Are you guys doing castellated nuts and cotter pins for the 6 AN4 bolts going into the ring too? I was planning on using undrilled bolts there with AN363 all-metal lock nuts...
PostPosted: Sat Jun 10, 2017 11:30 pm
I use castle nuts and carter , oops sorry cotter pins on everything that I can FWF that is flight critical . ;) Engine mount , carb/linkage attach points , exhaust ball joint , etc. Anything that if it fell off would cause me to enter high key and dead stick . ???
PostPosted: Sun Jun 11, 2017 12:46 am
I've had AN 363 all-metal nuts on the 4 bolts for my dynafocal mount for 27 years. I've only changed them once, when replacing the Lord mounts. They've remained tight and secure for roughly 1300 hours. The other T-18 in my hangar uses them too, for over 30 years. Same story. That being said, I'm using castle nuts and cotter keys on my "new" project. Either way is fine, in my opinion. Always use castle nuts on assemblies that can or may rotate in relation to each other.
PostPosted: Sun Jun 11, 2017 5:36 am
John, like you I have self locking nuts on my engine mount for 23 years, but the preferred practice is castle and cotters, go figure
PostPosted: Wed Jun 14, 2017 7:29 pm
Some of the work done the week:
* More nuts and bolts arrived for assembling the engine mount
* Painted the A-frame attachment point at top of firewall
* Cleaned intake pipes and oil return lines
* Disassembled exhaust pipe hanger to replace rubber - Cubes - do you sell 8" long x 2" wide x 9/32" thick rubber strips or a better substitute?
That's about it for this week - got a tough business-related weekend ahead so N12055 has to wait a week
File comment: Painted the upper longeron at top of A-frame
File comment: Cleaned intake pipes and aluminum oil return lines using Rolite
File comment: Exhaust support hanger with old rubber
PostPosted: Wed Jun 14, 2017 7:35 pm
Sorry John, I do not.
PostPosted: Wed Jun 14, 2017 7:39 pm
I went to a hose supply house and they had conveyor belt material . ??? Must be 6 ply/layer and very heavy duty . No need to double over . They sold me a strip for $1.00 . Enough for probably 4-6 hangars . :P It was stuff just sitting around taking up space . :o
PostPosted: Thu Jun 15, 2017 12:12 am
OK, no problem Cubes - it's one of those firewall-forward things anyways. Rich, thanks for the info about the 6 ply rubber. There are a ton of hose shops around here that have grown along with all the Marcellus Shale gas activities the past 10 years. I'll check with them but I don't think I'll get that kind of deal!
PostPosted: Thu Jun 15, 2017 1:51 am
Ask to look in their scrap pile. That's where I got mine.
PostPosted: Thu Jun 15, 2017 10:20 am
Don't hold me to the 6 ply comment . I was shooting blank twinkies when I said that . ??? It is a multi ply material that holds up very well . Number of plies will probably be based upon the type of belt material you find . I was using a material similar to what you have now and it didn't last long . The conveyor belt material has been in for several years and shows no sign of giving up . :P
PostPosted: Thu Jun 15, 2017 3:48 pm
Auto stores sells flex straps for exhaust, ever try cutting the sidewall out of an old tire?
PostPosted: Thu Jun 15, 2017 4:11 pm
I've tried the "flex straps" for exhaust from the local Autozone . Cheap Commie Crap made in China . :P Did not last long at all ! If I could fit a tire on a band saw to cut it up that might work . Much easier to get a squared up conveyor strip and then cut it to the size you need using a band saw . ;)
PostPosted: Fri Jun 16, 2017 6:56 am
Go talk to a farmer who has the equipment to make the big round hay bails. He will probably have some old straps from the bailer laying around. It would be a lot like the conveyor material Rich mentioned but likely easier to find close to Rostraver.
[ Time : 0.476s | 12 Queries | GZIP : On ]
