It is currently Fri Sep 04, 2026 10:06 pm
Post new topic Reply to topic  [ 196 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 14  Next
PostPosted: Sat Mar 05, 2016 7:58 pm
I need some, too.
PostPosted: Sun Mar 06, 2016 1:41 pm
Dick : I put my best men on it to search out and find das dust boot . ::) They found a boot which I believe came with my Cleveland MC's . Only one boot survived (could only find one) after 32 years and it appears to be in great shape (no cracks or tears) as it has only rarely seen sunlight . It does have a P/N on it and it is stamped "Made in the USA ." P/N is 12300 and Cleveland parts do come up , but no where is there a boot . I even checked to Cleveland/Parker parts catalog and it does not show a boot ? Since you were the first one to express an interest in the long lost artifact it is yours . Send me your address and I'll mail it to ya . ;)
Disclaimer...I do not imply that this part fits your intended purpose and you install it at your own risk . Your boot mileage may vary .
NX115RX
rx115@cox.net
PostPosted: Sun Mar 27, 2016 4:58 pm
Some of the work the past couple weeks. Fitting the floor panels and fabricating covers for the sticks.
PostPosted: Sun Mar 27, 2016 5:00 pm
I found some nice light weight sound deadening stuff at Lowe's
PostPosted: Thu Mar 31, 2016 9:39 pm
Today I made the part to allow the attachment of my 'seat' heat controller. It gets mounted on the forward tunnel
Im adapting a plenum for use under the cowl on TH
PostPosted: Thu Mar 31, 2016 10:50 pm
"Ummmm Seat Heaters ! DOH ! Looking good Homer .
PostPosted: Wed Apr 06, 2016 6:51 am
The intake pipes came back from the powder coat shop today. Part of the corrosion control program....
PostPosted: Thu May 12, 2016 6:53 am
I was checking the fit of the vertical stab, rudder and rudder cap yesterday. I decided that I prefer the cap to be taller. I sacrificed a second fiberglass cap I had in order to add material to bring the cap to the desired height. Today will be epoxy and micro balloons to finish the cap
PostPosted: Fri May 27, 2016 8:49 pm
I got word my GT propeller blades will ship Monday.
PostPosted: Mon Sep 05, 2016 10:09 am
Since the last update I have had the prop blades built into the propeller. It's all ready to mount on the engine sitting in the shop. I just require more space in the hangar before the rest of it happens.
PostPosted: Mon Sep 05, 2016 10:15 am
I also had the opportunity to spend 6 hours at Oshkosh in July. While cruising the exhibits with Cubes, I saw that Grand Rapids had just announced the Sport EX 7. The plan was to get the 8.4 GRT HXr, but this is a much better fit for the panel. And the price point is better as well. I've adapted the panel for the EX 7. Expected delivery is mid Sept. The balance of the panel is set up for 1 Garmin GTR-200 Comm, 1 Garmin GTX-327 Transponder. The box in the center is Grand Rapids EIS-4000. It collects the data from EGT, CHT, Fuel flow, OAT, etc. The electrical is covered by fuses and a couple breakers. All switches in this one - No Keys required.
PostPosted: Mon Oct 31, 2016 3:25 pm
Here's the prop for TH. hartzell hub with GT carbon fiber blades. 22 lbs lighter than a standard Hartzell.
PostPosted: Mon Oct 31, 2016 3:28 pm
IO-320 with the superior cold air induction system installed. Engine mount is attached and ready to hang on the fuselage.
PostPosted: Mon Oct 31, 2016 3:33 pm
Panel is just about ready for installation. Waiting for delivery of a Grand Rapids Sport EX 7. They announced it at Oshkosh this past year. I was told it would ship in October. All I need is the unit for final fit. Same for the Garmin GTR-200 comm. Then it all comes off for the panel to go to paint.
PostPosted: Mon Oct 31, 2016 3:58 pm
This panel does not have enough gauges to make it an airplane, HA!
I'm going to wood grain my panel this winter. Now I have veneer, but it will not hold up to the heat. I have a wood grain kit I use for the antique cars
[ Time : 0.091s | 10 Queries | GZIP : On ]
