It is currently Wed Oct 14, 2026 4:53 pm
 Post subject: A little tailwind
PostPosted: Thu Nov 12, 2015 5:18 pm
Was up flying yesterday evening and got a pic of the ground speed. It's in mph, but is the highest I have seen in my bird. Could have got to about 270 if I would have pushed the speed up a little higher in the descent. Was indicating 185 mph at 10,500 feet at time of pic. Where are these tailwinds when I'm going somewhere?!!!
Bernie Fried
N18XS
 Post subject: Re: A little tailwind
PostPosted: Thu Nov 12, 2015 7:44 pm
So this is your thorp with the new 0-320 power.... Nice numbers
PostPosted: Thu Nov 12, 2015 8:27 pm
Bernie : Did you end up getting the engine from Aero Sport Power ? :P
lance38dt
PostPosted: Thu Nov 12, 2015 8:35 pm
Bernie, I know you had an O-290, when you changed the engine did you use the old mount? I'm just thinking ahead .
Lance
PostPosted: Thu Nov 12, 2015 11:11 pm
Yes, I got the engine from Aerosport Power. It is a Superior 320 with crankshaft and rods swapped out, so it is a 340. The plane is probably 10 to 15 mph faster in cruise than with the 290. I am still breaking it in, so don't have real good speed numbers or fuel burn down yet.
Definitely a noticeable increase in acceleration and climb, and some increase in speed. Probably won't affect speed, but I don't have the spinner dome on yet.
I used the straight mount just like the 290 used (not dynafocal). The older narrow deck 320's are often straight mount (conical) cases. I think some of the newer wide deck Lycoming engines are also conical (maybe the 320b2b if I remember correctly), but not nearly as common as dynafocal. You can get new ECI and Superior engines with either mount style.
Bernie Fried
N18XS
PostPosted: Sat Nov 21, 2015 1:40 am
Was up again with a little more tailwind. Was getting 265 to 270 mph in cruise/level flight and got to 314 mph in descent. The new goal is 350!
https://www.youtube.com/watch?v=CVzAKaeYo3Y
PostPosted: Sat Nov 21, 2015 1:53 am
That's pretty cool Bernie!
One time coming home from Butte, Montana with my daughter in the right seat, we saw around 255 mph heading East towards Bozeman. I was throttled back too, because it got a little turbulent, & she was starting to feel sick. We did get home to Denver in record time that day though!
PostPosted: Sat Nov 21, 2015 6:01 am
Bernie, you sure your not in an A320?
campipilot
PostPosted: Wed Sep 21, 2016 1:38 am
So what do you think your normal cruise TAS is? Do you have a constant speed? If not what RPM are you running at cruise?
My bird does about 175 knots TAS at a bit over 2600 RPM 10,500' fixed pitch IO320 modified engine.
Users browsing this forum: No registered users and 25 guests
[ Time : 0.179s | 11 Queries | GZIP : On ]
