It is currently Wed Nov 11, 2026 6:22 pm
 Post subject: Oil change interval
PostPosted: Sat Aug 01, 2015 2:10 pm
Raise your hand if you change your oil every 4 months regardless of the hours flown as recommended by the oil manufactures and engine assembly Gods . ???
 Post subject: Re: Oil change interval
PostPosted: Sat Aug 01, 2015 3:28 pm
25 hours on the tach, no filter, regardless of calendar time. The next oil change is less than 1 month, 28 hours to OSH and back.
PostPosted: Sat Aug 01, 2015 7:43 pm
I raise my hand.
PostPosted: Sat Aug 01, 2015 9:07 pm
Rich,
I go strictly by hours too, like Bruce. I have a spin-on filter and have used AeroShell 15w50 since the beginning... 25 years. Engine still uses almost exactly 1 qt. in 25 hours, after 1300 hours. If I had to be down for a real long time, like maybe a year, I'd probably change it out. I do live in a nice dry climate.
PostPosted: Sun Aug 02, 2015 6:29 am
I use the tach, as well: every fifty hours. I have a full aircraft filter. I use one quart in 15 hrs unless I have done some aerobatics, in which case it throws some out. Then I get about ten hours to the quart. I maintain the level between six and seven quarts.
PostPosted: Sun Aug 02, 2015 1:37 pm
I use the tach. I do change at 25 hours even tho I have a spin on KN filter. My mechanic asked me why and I told him I don't like what the oil looks like past about 30 hours. He said good enough. My engine is old and has some blow by. It dirtys the oil more than some.
PostPosted: Tue Aug 04, 2015 6:38 pm
Thanks for the info . ! ;) I think the majority do the tach/hobbs meter routine . I just wanted to check with my cell mates to see what they were doing . ???
PostPosted: Wed Aug 05, 2015 6:55 am
25 HRS, I juss figgered the oil in the sump wouldnt wear out any faster than the oil sittin in the one qt Containers on the shelf...Dan
PostPosted: Wed Aug 05, 2015 10:33 am
You're probably right Dan ...it's been sittin in the ground for 65 million years ! ???
[ Time : 0.145s | 10 Queries | GZIP : On ]
