It is currently Sun Nov 15, 2026 1:06 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Sep 15, 2014 1:50 pm
Hi Dick,
The flap skins were one of the more difficult pieces to form for me. I wasted a lot of material. There is a lot of info in the old newsletters and some good ideas about how to do it. There was also discussion about using .020" instead of .025" material, as this would be easier to form. I don't know if John Thorp ever confirmed that this would be OK or not, at least in writing. I know that there was discussion about how he supposedly chose .025" in order to utilize existing material & not have to purchase .020" just for this one assembly, & that .020" would be fine. I can't confirm that. Anyway, to your question... this is what I ended up doing. Like Bob said, extra material which is then trimmed away is very helpful. The pictures are of my test strip which I used to develop a sequence which produced an acceptable shape for me. The thing is old & beat-up now, but I hope you can read the markings on it. I made a hole transfer strip to lay out the series of identical holes to hold the skin in "folded" position with clecos. I started with the more gradual upper portion of the curve first (#1 set of holes) & pushed the skin down with a large board (just like we do to form the wing skins), but used a 3" thick "spacer" (2 - 2x4s) in between to automatically limit the amount of bending. I then proceeded to using the other lines of holes in sequence, but this time decreasing my "spacer" thickness in steps down to 3/4" for all the rest. It came out as you see in the last picture. I hope this is halfway clear to you. I'm not saying this is the best or easiest way to do it, but it's what I did.
PostPosted: Sun Sep 21, 2014 7:03 pm
Thanks for the good advice, Bob and John. I guess the leading edge is doable.
Here`s the damage:
PostPosted: Sun Sep 21, 2014 7:24 pm
I looks to me like you might be able to just straighten the skins out and maybe replace the outer rib unless there is more than I see
PostPosted: Sun Sep 21, 2014 9:25 pm
Worth the try to "bang" out the dents before putting together a new one . Once the skin is as smooth as possible a "thin" coat of a high grade filler followed by a color coat might do the job .
PostPosted: Sun Sep 21, 2014 10:49 pm
I agree with David and Rich, Dick.
PostPosted: Mon Sep 22, 2014 12:32 am
I agree with David and Rich and John, Dick.
Bernie Fried
N18XS
PostPosted: Mon Sep 22, 2014 7:19 am
Really? Well that's encouraging. I didn't even consider bending the skins back as a viable option.
I gotta get mo one of those Easy Buttons from Staples. I do tend to make mountains out of molehills. Thanks guys!
d
PostPosted: Mon Sep 22, 2014 7:23 am
I agree with those that would agree with the above.....Dan
PostPosted: Thu Oct 16, 2014 8:28 am
I am happy to report a successful engine run. I wheeled the airplane out of the garage on Saturday Oct 11. Finished up some little wiring details, some plumbing, stuck the tailpipes on, and cranked 'er up. It took two tries since the fuel bowl was empty, but once she caught, she started up like nothing for the first time since Oct 2010. She ran nice and smoothly and all parameters showed green on the MGL EMS. No leaks, and the bonus was that my innovative fix for the pesky oil leak on the front of the case was completely effective. Looks like I have me a bone-dry engine. (Knock wood.)
I've been grinning like a goofball every since. Will share the timelapse video when I figure out how to make it available.
PostPosted: Thu Oct 16, 2014 9:35 am
Now that the noises are from a real engine instead of from a kazoo, microphone and the PA from inside the garage, would imagine you're getting fewer visits from the neighborhood shrinks.
Congrats!!
mattst18
PostPosted: Thu Oct 16, 2014 11:35 am
Images: 43
Way to go Dick!
Matt Smith
Des Moines, IA
55RC
PostPosted: Thu Oct 16, 2014 6:36 pm
Fire in the hole!!! Way to go Dick, keep wearing that grin, you deserve it......Dan
PostPosted: Sat Oct 18, 2014 11:45 pm
Engine run...
PostPosted: Sat Mar 05, 2016 6:14 pm
Remember my flap skin crisis? I made a slapper. It worked quite well. Now I just have to touch up the paint.
mattst18
PostPosted: Sat Mar 12, 2016 1:08 am
Images: 43
Looks good!
Matt Smith
Des Moines, IA
55RC
[ Time : 0.693s | 12 Queries | GZIP : On ]
