It is currently Thu Oct 01, 2026 2:22 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
Hoov330
 Post subject: Wing Tips
PostPosted: Sun Dec 05, 2010 11:16 pm
Anyone have a extra set of wing tips they want to part with.
Jerry
J. Hoover
N330JH
Yelm, Wa
admin
PostPosted: Mon Dec 06, 2010 8:39 pm
Did you want those in black or brown? Size?
*** admin posted for Mark Green ***
Forum Administrator
Hoov330
PostPosted: Tue Dec 07, 2010 1:55 pm
Also have a set of Klebler tips that are brand new from Classic sport. I think they are for the S-18 wing because the profile is not the same as mine.
J. Hoover
N330JH
Yelm, Wa
PostPosted: Tue Dec 07, 2010 6:12 pm
Jerry: I have a set of Metal T-18 standard tips. If you are interested I can take pics and post them. I believe they are plans made. No dents. Will require a little work to smooth the welds. I did not make them. The welds appear to be done professionally.
If anyone wants to buy a set of standard S-18 tips, I have them also. CSA made set. One tip has been cut ( and repaired ) I intended to install the Vans Nav lens, but it was way toooo big, so I put the cut back in. No attach holes drilled. Will still require finish sanding prior to primer and paint. Paid $180.00 for the pair, asking $100 and I'll pay the shipping. If you don't like them return them (you pay the return shipping) and I'll refund. [;)]
Image Insert:
Put File Caption Here
Scott Saver
PostPosted: Tue Dec 07, 2010 7:35 pm
Rich,
I'm interested in the metal wingtips if they are still available. Can you post a picture. Contact me off list if you want.
Scott Saver
PostPosted: Tue Dec 07, 2010 7:52 pm
I was going to give Jerry first crack at the metal tips (he was looking for standard tips) as his name floated to the top first. If he wants them I was going to try and do a swap for the Kelbler tips...are you listening Jerry ? I will post a pic of the metal tips tomorrow AM. If he does not want them, then you are next in the barrel. Just looking at the English wheel work on the curved portion of the tips is WAY out of my league !
Hoov330
PostPosted: Tue Dec 07, 2010 9:58 pm
Rich,
Thanks for the offer, give Scott the shot and thank you for being so honerable. not sure what im going to do yet, someone mentioned that i could modify the s-18 klebler tips to fit the standard wing. dont know if its possible.
J. Hoover
N330JH
Yelm, Wa
PostPosted: Tue Dec 07, 2010 10:11 pm
OK. Scott, I'll post the pics in the AM. It may be possible to "reshape" the "K" tips with a heat gun ? Thunk I read it on a post a while back ? Waaaay back.
N89BJ
PostPosted: Wed Dec 08, 2010 11:05 am
I have not heard of Klebler tips. What is different about them?
PostPosted: Wed Dec 08, 2010 11:48 am
Scott: Here are the metal tips. Standard T-18. NO dents. No holes drilled. Got a pic as close to the welds as I could. No distortion in the metal, which is amazing. Mating edge needs to be trimmed/squared. Weld needs buffing/polishing/smoothing. Put the wing tip on the full scale plan and the profile is very good. Asking $125.00 for the pair + shipping. If you don't like them, ship them back (same condition) and I'll refund. Please advise.
Image Insert:
Image Insert:
Image Insert:
PostPosted: Wed Dec 08, 2010 12:03 pm
Different profile than the standard tips. Research the NL's and past messages for more info. Someone did a very good write up on them ? I like the look and the claim to give more lift. [;)]
NX115RX
Image Insert:
PostPosted: Wed Dec 08, 2010 2:42 pm
Jerry,
Aircraft Spruce has original T-18 wing tips listed in their catalog http://www.aircraftspruce.com/catalog/appages/mt1.php, or if you want Klebler tips, there is a good write up by John Evens on how to make a pair in the File Library under Miscellaneous, look for file "wing_tips.doc"
Hoov330
PostPosted: Wed Dec 08, 2010 4:51 pm
Thanks, I did see those on A/S thats the direction im leaning at this point, I might get a glass guy to modify these or just sell them. Mike told me they would fit with minimal modification, but the two guys i talked to said it would be considerable if you dont want a hack job.
J. Hoover
N330JH
Yelm, Wa
Scott Saver
PostPosted: Wed Dec 08, 2010 5:49 pm
Rich,
Sounds like a deal. Can you send me your mailing address so I can send you a check. Jerry, I have an untouched set of standard fiberglass tips from Spruce. If these metal ones work out, these are certainly available. I'll look and see what I gave for them and will try and post a picture of them tomorrow if you are interested.
Scott Saver
PostPosted: Wed Dec 08, 2010 7:18 pm
Scott: Here is my address. Don't send the check yet until I figure out the shipping. My wife has a company account with UPS and gets a really good deal on the rates...not quite free, but pretty close. [:p] I need your address to figure out the shipping rate. I also need to "construct" a suitable shipping container for the tips and that will take me a few days. These beauties have not one dent in them and I would like to keep them that way ! [8D] You can also use the container to return the tips if they are not to your liking.
3781 Hidden Trail Dr.
Jamul, CA 91935
[ Time : 0.101s | 10 Queries | GZIP : On ]
