It is currently Tue Oct 13, 2026 6:04 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Landing Lights
PostPosted: Thu Mar 06, 2014 2:23 am
Look what I installed last night. Thanks Dave Read for telling me about your landing lights. Superbriteleds.com p/n AUX-10W-R25B (Auxiliary light, 10 watt, 25 degree spot beam, black). $49.95 ea.
Will finish the electrical installation this weekend. Tony
PS - Happy B-day, Bill W.
PostPosted: Thu Mar 06, 2014 7:58 am
Looks like you guys found the "Right Stuff". How about a night-time pirep?
PostPosted: Thu Mar 06, 2014 8:04 am
Tony, that looks good. that really pushed me over the edge on my decision to try the cowl inlet first. I would like to hear a night time pirep too.
PostPosted: Thu Mar 06, 2014 8:19 am
Guys,
Here is my landing light installation.
PostPosted: Thu Mar 06, 2014 11:56 am
Jim, that looks good too. I like the idea of a light in the wing and/or in the cowl as the sexiest options (in my opinion). But, I cant bring myself to put a blade to the wing or cowl and start cutting. I enjoy these little tinkering projects that I can accomplish while still having a flyable airplane. I can see myself making a bad cut in a wing (or cowl)....I would be devastated.
PostPosted: Thu Mar 06, 2014 3:19 pm
I like the install Jim , that's clean......Dan
PostPosted: Thu Mar 06, 2014 6:35 pm
LED lighting is the way to go . Small compact and CHEAP and it last a long, long time ! :o I just heard everyone in the room turn up the sound ! ::)
PostPosted: Thu Mar 06, 2014 8:44 pm
Yep, I agree Rich I believe before long LEDs will take over about everything including the automotive stuff. Dan
PostPosted: Thu Mar 06, 2014 10:16 pm
I put the led lights Tony mentioned in the wing gap covers. That way if I didn't like them I have only messed up the gap covers. I have a very short video that shows how they work. You can see the runway numbers and centerline when you get fairly close. I had a 75w halogen in the right cowl inlet before, never had a problem with reflection off the prop.
trim.DA4CA3F7-85BC-40B5-9CF3-58C0BD8F2F14.MOV [424.4 KiB]
Downloaded 989 times
PostPosted: Thu Mar 06, 2014 10:17 pm
Oops, guess I will have to get some help with the video
PostPosted: Fri Mar 07, 2014 10:49 am
I would like to see that Video David, the gap cover lights would seem to be a novel idea! certainly easy to get to.....Dan
PostPosted: Fri Mar 07, 2014 11:57 am
Dan you should be able to click the link now and view the video.
PostPosted: Fri Mar 07, 2014 5:25 pm
well, after all that heartburn about a push pull cable, I went out to the plane this afternoon and installed landing lights in the cowling inlets. I went and flew and there was no ill effects. I put in four 55W lights, two in each cowl inlet. My 60Amp B&C Alternator will earn her money during night landings!
PostPosted: Fri Mar 07, 2014 7:56 pm
And the crowd went wild ! :P They want more ! :o
Pacer 20
PostPosted: Sat Mar 08, 2014 1:57 pm
Interesting set-up. Are you installed 2 on each side or just on the right side of the cowl and
are you routing the electrical wire on the top of the engine or along the valve cover?
Thierry
French Canadian T-18
C-FPVE #091
[ Time : 0.263s | 12 Queries | GZIP : On ]
