It is currently Sun Nov 15, 2026 1:18 am
Scott Stine
 Post subject: Cowling Fastners
PostPosted: Fri Nov 19, 2010 11:55 am
Images: 5
Quick Survey Folks
I am setting up to locate fastners for my CSA fiberglass cowling. I am planning on using Milspec adjustable C lock fastners.....really cool and eliminate the multiple stud length issue. I have seen Tom Hunters pattern of 6in cheek top spacing and 10in bottom spacing buthe is using a metal cowl. How about it glass guys....what spacing is enough but not too much......4in.....6in....?
THanks Scott
Scott Stine
Vincennes, IN
812-881-7923
Arrow 545WA
PostPosted: Fri Nov 19, 2010 12:38 pm
Dr.,
N51863 has Seven on top, Eight on the bottom, 1 in the front centered.
X X X X X X X
X
X X X X X X X X
Hasn't scalloped yet (30+ years)
PostPosted: Fri Nov 19, 2010 1:50 pm
You will bee very happy with the MilSpec adjustable locks. [8D] I used them. You're right, only one length stud is required. A wee bit more $$$ than the standard type, but worth it. You can carry a couple of spares (studs...same length) with you. [;)] Go with the S/S studs.
RX115 has the following pattern on it's CSA cowl.
x x x x x x x
x (6) Side cheek Top.
x
x
x (8) Approx. 3" spacing...Top cowl rear.
x
x (8) Approx. 5" spacing Side cheek, Bottom
x x x x x x x x x
The top of the cowl cheek has a few less fastners than the bottom due to the cowl cheek concealed hinges I installed.
DO NOT skimp on the spacing of the locks to save a few bucks ! The MilSpec site will also give you a recommended spacing.
PostPosted: Fri Nov 19, 2010 6:55 pm
Scott,
Check out WWW.skybolt.com This outfit is owned by a friend of mine and makes some really neat CamLock type fasteners. I recommend you look at the CLoc 4000 series common sets. The N-3 stud holder is made for fiberglass as it has a wide flange.
N711SH has the following setup for the studs:
XXXXXX
X
XXXXXXX
Make sure you check where they fall as you can really make a mess if don't check clearance on baffles and exhaust pipes.
chuck
PostPosted: Sat Nov 20, 2010 7:22 am
Glass Guru's,
Guy's I'm attaching a new scoop also and it's going fairly well. However, I keep getting some scalloping, I tried a heat gun which removes much of it, but once it cools some returns. Any thoughts on how to get it to
Image Insert:
Put File Caption Hereflatten out?
Chuck Kincer
Chuck Kincer
Richmond, Me
575CK
KIWI
PostPosted: Sat Nov 20, 2010 7:33 am
Chuck,
You need to build it up with some more glass, and possibly add a stiffener. It's scalloping because the material is too thin.
When you're building it up you can sandwich a strip of aluminum in there as well, that'll help keep it down too.
chuck
PostPosted: Sat Nov 20, 2010 8:16 am
Ah.....I hadn't thought about adding more "beef". If all goes well today's project.
Chuck
Chuck Kincer
Richmond, Me
575CK
KIWI
Scott Stine
PostPosted: Wed Jan 12, 2011 4:21 pm
Images: 5
These are the MILSPEC ajustable camlock fastners. Same footprint as typical fixed models. Interestingly, the floating model is more expensive than the fixed due to mfg costs. Expensive little buggars, but seem to be worth it. All use the same stud length and then are adjusted by screwing in or backing out the threaded insert. Once adjusted the pin is pulled and they stay in place. They also make really nice SS grommets...S....M....L.
Image Insert:
Scott Stine
Vincennes, IN
812-881-7923
Arrow 545WA
PostPosted: Wed Jan 12, 2011 10:41 pm
Yep...these are the ones I used. The beauty is being able to use the same length stud for all the locks ! Well worth the little extra for the adjustable, over fixed units, not having to try and figure the proper stud length for each location. Put a spare set in the pack up kit, just in case I need one. I posted the MILSPEC site on the vendors list quite a while back.
[ Time : 0.175s | 11 Queries | GZIP : On ]
