It is currently Wed Feb 19, 2020 11:15 pm
Cook11
PostPosted: Thu Aug 16, 2018 4:33 pm
Can anyone supply me some pictures of what the Aircraft Spruce MC-4 nose cowl looks like? Also what prop spinner fits this nose cowl?
Thanks!
PostPosted: Fri Aug 17, 2018 7:48 am
I hope this helps: https://www.skyshop.com.au/pdf/2009-201 ... %20196.pdf
PostPosted: Fri Aug 17, 2018 3:18 pm
I’m sure Cubes has the appropriate spinner for this application whether you go fixed pitch or constant speed
T
PostPosted: Fri Aug 17, 2018 3:22 pm
I believe Bernie has the nosebowl you ask about
Cook11
PostPosted: Thu Aug 23, 2018 11:50 am
Thanks for the info guys!
PostPosted: Fri Aug 24, 2018 2:45 pm
I have the Aircraft Spruce MC-4 nose bowl with the MC-5 bottom pan. The spinner is a BN-3 from Spruce also. The cowl was slightly larger than spinner trailing edge, so did some work on cowl to make it match spinner. The cooling air inlets were closed up a bit and the bottom pan was modified with the exhaust outlets and ram air intake.
PostPosted: Fri Aug 24, 2018 5:17 pm
One of the nicest T-18's I've seen !
[ Time : 0.062s | 13 Queries | GZIP : On ]
