It is currently Fri Oct 30, 2026 4:24 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3, 4  Next
Pacer 20
 Post subject: Tank for sale.
PostPosted: Wed Aug 14, 2013 9:20 pm
I search for a new or a very good serviceable T-18 fuel tank.
Keep me posted.
Thanks.
Thierry
French Canadian T-18
C-FPVE #091
 Post subject: Re: Tank for sale.
PostPosted: Fri Aug 16, 2013 12:32 am
Check with Mike and Richard first, see what they have going on in the way of tanks or parts.
If you can’t come up with something I can do one up.
Pacer 20
PostPosted: Fri Aug 16, 2013 7:38 am
Thanks Lou.
Do you have the info about Mike.
For Richards I have is number.
Via my PM if you prefer.
Et voila'!!!
Thierry
C-FPVE #091
PostPosted: Fri Aug 16, 2013 10:02 am
Both Richard and Mike's contact info is on the main page of the forum under "Our Suppliers"
Pacer 20
PostPosted: Fri Aug 16, 2013 4:46 pm
Thanks.
I found the info and I send the e-mail to Mike.
Thierry
C-FPVE #091
PostPosted: Fri Aug 16, 2013 10:04 pm
If I had to do over my tank , I would make the larger tank like David Read did . I think his is 40 gallons ? No need for wing tanks , pumps , extra hoses etc . ;)
Pacer 20
PostPosted: Fri Aug 16, 2013 11:04 pm
Rich.
I have a good idea.
I buy your standard fuel tank and after is the perfect timming for you to install the 40 gallons drum on your plane!
Deal or No Deal...
Thierry
C-FPVE #091
PostPosted: Fri Aug 16, 2013 11:22 pm
Thierry : My tank is staying right where it is . You have the perfect opportunity to upgrade from the standard tank to an extended range tank . I know Mike and Richard don't make the larger tank , but Lou ....? Lou is an outstanding welder ! This might be an area that does not infringe on Mike or Richard with regard to copyright laws . When I was building , I looked at the standard tank and thought there might be a way to increase the size of the tank ? David Read did that .
PostPosted: Sat Aug 17, 2013 8:44 am
Bearing in mind, of course, that the Read Tank also requires a modern panel to free up the space for more fuel.
PostPosted: Sat Aug 17, 2013 4:13 pm
Dick : This is true , but I think Thierry is in a good position with the old tank out . Not sure what type avionics he had in the old panel , but now would be a good time for an upgrade in that area also if needed so he could install a larger tank . I just like the idea of a larger main tank as opposed to the wing/drop tanks . ;)
PostPosted: Sat Aug 17, 2013 5:50 pm
I do too. Depending on motor and prop selection, of course. The W n B could be a bit out of control for a big motor with CS.
Pacer 20
PostPosted: Sat Aug 17, 2013 9:37 pm
I have a 0-320 engine. No prop at this time.
I have the possibility to install a CS prop but is heavy.
I have 3 different prop in my target.
-Cato
-Composite Sensenich
-Ed Sterba
40 gallons in the front... I have to check the W and B. Maybe to nose heavy???
I have to rebuilt all my wing centre section. Wet wings is not my best option. I like the external fuel tanks but the 5mph speed lost is my trouble.
I know is the time to take a decision and make some modification because when I finish this project I don't want in 2 years to re-open all the panel and install other stuff inside my T18!
What is the best way, stay with the original fuel design or....
Thierry
C-FPVE #091
PostPosted: Sat Aug 17, 2013 10:55 pm
Cubes is right . CS will add a butt load of weight to the nose , even with a composite CS.
Round numbers I found are...
Metal CS around 40 + pounds .
Metal fixed pitched 30 + pounds
AD prop 13 pounds .
PostPosted: Sat Aug 17, 2013 11:41 pm
If you want more fuel I think that a “Read tank” Is the way to go but 40 gal may be over shooting the mark by four to six gallons. Hold a standard 29 gallon tank in your hands, damn that’s a lot of gas.
If SOMEBODY wants to go to the trouble to start building more than one XL center tank then it would be a very good idea for you/us/Mr. Read to kick this around a bit and come up with a consensus on just what is the perfect size. Obviously David’s experience will be most valuable.
There is a lot of work that goes into building one of these things and it does nobody any good to have a bunch of different sizes of tanks floating around out there. A new tank pretty much means new tooling of some sort.
For me, sure I could use more range as I’m being lured deeper into the mid west for flying and BBQ but for now I’m focusing on less weight and less drag.
Pacer 20
PostPosted: Sun Aug 18, 2013 7:46 am
40 gallons is lot of weight. Around 240 pounds on the nose versus the standard 175 pounds.
Around 36 gallons is better for me.
I know I have no reason to full the 40 gallons tank each time I flew the plane but is lot of weight...
Ok guys wath is the best way to contact MR long range?
Merci!
Thierry
C-FPVE #091
[ Time : 0.184s | 12 Queries | GZIP : On ]
