It is currently Tue Nov 04, 2025 12:19 pm
 Post subject: Exhaust Pipe Fairings?
PostPosted: Fri Apr 19, 2013 12:10 pm
Does CSA (or anyone else) sell exhaust pipe fairings? I am hoping to find something pre-made that would clean-up the area where my exhaust pipes exit the bottom cowl.
PostPosted: Fri Apr 19, 2013 1:25 pm
Newsletters and/or elsewhere on the this site (or the old one.) I remember some great photos where the fellow stuffed the flat stock through a slot in a piece of plywood and trimmed it later. Dick Penman may also have written an article on something similar back in the day. I vaquely remember a sketch.
PostPosted: Fri Apr 19, 2013 3:23 pm
CSA did have them (fiberglass) . Not sure about the status now ? Yes...someone did make aluminum fairings from a form block . Did not seen difficult . Can not remember who it was ? ??? It was in a past NL . ;)
PostPosted: Fri Apr 19, 2013 4:40 pm
It's silly easy, I believe Dr. Stine has posted pics of the process.
PostPosted: Fri Apr 19, 2013 4:45 pm
I wrapped a piece of .032 around a 2 1/2" PVC, bent ears with a brake and riveted them on the Aluminum cowl
PostPosted: Fri Apr 19, 2013 6:46 pm
Bill : Let's not make it a complicated process ! :P
PostPosted: Fri Apr 19, 2013 7:26 pm
I just returned a set that Spanky bought back to Mike at CSA.
PostPosted: Fri Apr 19, 2013 8:15 pm
The fiberglass set I got from CSA fit just fine . I did not mount them on the surface of the cowl . I made a cut out and glassed them in flush . ??? A lot of work for a guy that has little work working with the slime ! :P
PostPosted: Fri Apr 19, 2013 8:49 pm
Bill and Lee make it seem so easy that I would be ashamed to admit whether I will make my own or buy a set from CSA.....but I really should help support CSA....thanks for all the info.
PostPosted: Fri Apr 19, 2013 10:32 pm
We need to support our Vendors! Back when I bought the fiberglass fairings , I think they were $8.00 each ? That was a while ago , but I consider that a bargain not having to make a mold , lay the glass , mix the goo and do layer upon layer . My time is worth more than that and by the time I buy the supplies the cost is not that much different . Some parts I could do with regard to the AC and others I left to the Vendors .
PostPosted: Sat Apr 20, 2013 5:47 am
It was Dr. Stine.
[ Time : 0.065s | 10 Queries | GZIP : On ]
