It is currently Sun Nov 02, 2025 5:59 pm
 Post subject: flap return springs
PostPosted: Mon Mar 18, 2013 1:49 pm
Hey Guys,
Not much detail in the plans for flap return springs on folding wings. I have to assume it takes one for each, that makes 4. Kinda hard on the mechanism I suppose, so do you suppose going a little lighter on the spring rate? got a nice fit with the wings, but so far I haven't folded mine with flaps attached. I suppose it doesn't affect making them 'mesh' together, except you have farther to reach over.
Appreciate your thoughts.
Les Krumel, Albuquerque
 Post subject: Re: flap return springs
PostPosted: Mon Mar 18, 2013 2:56 pm
I would stay with the (4) springs . (2) might reduce the retract rate ? I used (4) . Some folks install the inboard flap spring inside the fus . and attached it under the seat .
PostPosted: Mon Mar 18, 2013 5:29 pm
I used four in the wing joint area. Keeps the space under the seats cleaner in the event you want to put stuff under there. I keep extra oil and cleaning supplies there. The individual springs on each flap make it better when you take the outer wing panels off. The flaps don't "flap" around when separated.
PostPosted: Mon Mar 18, 2013 6:49 pm
Bob: Good point about flapping around . I hadn't thought about that aspect as I trailer . My (4) are in the wing joint area . Yep...I keep a lot lot stuff under the seats ! :o ELT , tool kit , a few spare parts (couple of plugs , nuts/bolts , zip ties , safety wire , etc. ) , first aid/survival kit , tie down ratchet straps , oil and possibly a dead body ! Could be Hoffa , but it has been a while since I looked ! :P BOOM !
PostPosted: Tue Mar 19, 2013 1:32 pm
Thanks guys,
Yeah, there's too much flappin goin on in the world. I'll go with 4, but there's also wiring and fuel lines to deal with in the gap too. I'll make it work. Posted new pictures on the gallery yesterday. Making progress...
Les.
PostPosted: Tue Mar 19, 2013 4:08 pm
I put PVC tubes down the trailing edgesjust ahead of the rear spar wing joints. Made AMP connectors for the strobe and nav light wires. Fuel lines and fuel low level wires join in the gap ahead of the main spar. Pitot and static lines join there, too. My fuel pumps are in the stub wings and do not come off with the wing.
PostPosted: Tue Mar 19, 2013 7:39 pm
Did just about the same thing , except I used a thin wall aluminun tube vs. pvc . ;) Wires (strobe , Nsav and landing lite ) at the joint use the Deutsch connectors and the pitot line uses a quick disconnect . 8) I was able to flare the aluminum tube to eliminate the sharp edge ! BOOM !
[ Time : 0.078s | 12 Queries | GZIP : On ]
