It is currently Fri Oct 23, 2026 5:57 am
Post new topic Reply to topic  [ 252 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 17  Next
Pacer 20
 Post subject: Re: C-FPVE
PostPosted: Wed Feb 20, 2013 9:38 pm
Wednesday report!
Inside doubler finally prime. It's time to make some riveting noise.
Happy with the result. Door need final adjustment only when I install the locking mechanism.
I patch this hole at my coffe break tomorrow.
Hole festival.... In February!
My work for the next month. I prefer my T-18. I'm not able to put 23 us/gal of 100LL in economic cruise.
Cheers!
Thierry
French Canadian T-18
C-FPVE #091
Pacer 20
PostPosted: Fri Feb 22, 2013 3:25 pm
Coffe break time.
I start to made some design to patch my bottom skin. Some cu-out with inside doubler and a flush patch. I dont like this idea. No-body see the bottom of this plane but I decide to remove the entire skin. Quick check and I have a brand new aluminium sheet in my stock room. So.....licence to dril >:D
Operation time 2 and a half hours. Ok plus my beer time!
Now I have to found somebody to help me to install rivets :) :) :)
Thierry
C-FPVE #091
PostPosted: Fri Feb 22, 2013 3:56 pm
Nice job ! This is where I found Cherry Max rivets to be my best friend ! No help to buck and I can't reach it by myself . BOOM !
Pacer 20
PostPosted: Fri Feb 22, 2013 4:15 pm
Thanks :) :) :) MrBrazell!
Cherrymax and PRC was a great combo but the price was expensive when you have to install a complete skin. Otherwise if I find a friend to help, I have to calculate: the beer, pizza lunch, cofee, doghnuts and all the rest. Finally the same price of a bag of Cherrymax!!! And a couple of week later the same friend call you to help for some backyard job at his house :-\
What is the best way....
Thierry
C-FPVE #091
PostPosted: Fri Feb 22, 2013 5:22 pm
Go to E-Bay . There use to be a guy from Canada that was selling Cherry Max rivets in 1000 piece lots . 10 bags at the time and he was getting $100.00 + shipping ($10.00 a bag) . I bought 2 orders from him and still have most of the second order to use for "repairs." You could even specify the length . Last time I looked he was up to $120.00 per lot + shipping . Shipping from Canada to California was expensive , but even with the shipping is was one hell of a deal compared to Spruce where it was around $50-60 per 100 of 4-2 flush CM rivets . Not sure if the guy is still listing on E-Bay ?
PostPosted: Fri Feb 22, 2013 8:30 pm
I checked E-Bay and the guy from Canada is still selling the Cherry Max rivets...1000 piece lots . He lists the lots in a group of different sizes , but I asked him to send me all one size and he did . The all important 4-2 . Price has gone up , but I think it is still a very good deal compared to any vendor in the US . :P You guys in Canada he might be living right next door ? :o
Pacer 20
PostPosted: Mon Feb 25, 2013 11:23 pm
Bonjour!
Last week of work before my kids winter vacation. I closed the shop Friday and I coming back March 11, so I rush to finish all the metal in the tail fuselage section for the end of this week. I want to install the stabilisator to see if my hole was parallel to both support. I rebuilt all the tail section via the plan but I want to be shure before it was too late. I dont want to put all 5/32 rivet everywhere to mask my mistake.
Tail wheel support are all in place.
A real cleco plantation.
First inspection at the vertical fin. Another major repair! Not repair I have to built a brand new fin.
I need more vocabulary for this job :-\ :-\
Please give me more english expression. In french I have lot of good words but if I talk in french nobody understand on this forum. ^-^
Cheers!
Thierry
C-FPVE #091
PostPosted: Tue Feb 26, 2013 6:23 am
Thierry,
It would be better if you make the steel angle for the rear tail spring support wider the join the bottom longerons as well. We have experienced cracking of this piece if built to plans.
Too bad about the fin. A new one is in order. If your vacation includes Florida, look us up.
Pacer 20
PostPosted: Tue Feb 26, 2013 10:23 am
Fytrplt.
Do you have some dimension about the new part? Is it for both steel plate or just the rear one. Same thickness
or not ?
Thanks.
Thierry
C-FPVE #091
PostPosted: Tue Feb 26, 2013 2:24 pm
Thierry - below are a few photos of what I ran into - and how I repaired it - note the repair spans the bottom longerons - what is not shown is two 1/4 inch bolts per each side. I used the existing rivet holes - drilled them out and put the bolts through the repair piece locking everything together - there is also a spacer between the new piece and the skin (between the longerons) - I cannot remember the thickness of the repair piece at the moment, but the whole repair may at least give you some guidance as to how to make that area stronger.
It's been almost two years and is working well.
PS.....J'ai reste a Ville de Quebec puis Montreal (Brossard) pour plus de 6 mois - je comprend "colon" francais pa mal....:)...though it has been quite awhile since I spoke it.
PostPosted: Tue Feb 26, 2013 8:23 pm
Thierry,
Just the rear one needs to go the full length as it takes up the side loads from the tail spring. Mine is the same width as the original part, but extended to pick up the bottom longerons. I don't recall the tickness, but I think it was as called out in the plans. As stated by Monsieur Fraser, you may need a spacer to level up the angle across the bottom skin and the longerons.
Pacer 20
PostPosted: Tue Feb 26, 2013 10:06 pm
Stabilisator in place, fit was perfect! Last hole punch and ready for the next step.
Quick view about the torque tube...Hum I have to check the plan to see this miss match between bolt and rivet! Sounds no good for me...
Lot of chaffing on this area.
Inside of the torque tube. Some rivet are very to much crush but...... I have to check with the SDR Horizontal tail Spar Doubler to be shure is in place.
All skin removed and tomorrow is the priming day. I have to made a new 4130 stel plate for my tail wheel attach. Thanks for the picture Fraser MacPhee and for the doubler info fytrplt. I appreciate.
Thierry
C-FPVE #091
PostPosted: Tue Feb 26, 2013 11:18 pm
I have serious doubts about the spar tube/fittings ! C:-) My first clue is the use of bolts in place of the required rivets . :'( This would increase the the hole size in the spar tube/fittings . The use of the bolts is probably because of the poor riveting job job on the spar tube (inside and out) as shown by the photo . I also see "pop rivets" that were used to attach the doublers on the top of the stab skin . I would have serious doubts if they are structural "pop rivets." They are not CM rivets . The chaffing is probably due to not enough of a cut out on the fus. skin or on the top access panels that cover the fin area . From your pic of the inside of the tube you should be able to see the spar tube doubler ? ;)
IMHO I would drill out the skins and redo the spar tube and fittings and make sure the spar tube doubler is installed . It would also be a good time to see if the SS stiffiners were installed on the tabs . At the speed you are working and the quality of your work from the photos , redoing the stab would be a piece of cake ! ;) The over "bucked rivets" as shown inside the spar tube may be due to incorrect length ? ???
PostPosted: Tue Feb 26, 2013 11:22 pm
OK Fraser I guess I need to take another H.S. language class ! "UN , DEUX , TRUIS , QUATRE !" "Oh La' La' , "Mon Dieu' " :o
PostPosted: Wed Feb 27, 2013 6:55 am
Be very wary of that spar! Those look like soft skin rivets and the deviations at the fittings could mean they were installed wrong and refit. One of the fittings at least, needs to be removed and the spar underneath inspected.
[ Time : 0.523s | 13 Queries | GZIP : On ]
