It is currently Sat Sep 13, 2025 6:09 pm
smokyray
PostPosted: Fri Aug 24, 2012 11:48 am
I have a Landoll Harmonic Dampener for the 0-320/0-360. It bolts directly to the flywheel, dampens harmonics with a wood prop and adds 9lbs to the nose. 250 hours on it with no worries, like new includes bolts. New cost $400.
$125 shipped to your door.
Rob "Smokey" Ray
863-397-1657
smokyray@rocketmail.com
smokyray
PostPosted: Sat Aug 25, 2012 1:27 pm
Sold, thanks for the interest!
Smokey
PostPosted: Wed Jan 23, 2013 9:45 pm
If any of you guys come across another one of these - I'm in the market.
thanks, Terry
PostPosted: Thu Jan 24, 2013 1:34 am
I have one. It's been sitting on a shelf for a little less than a year. Ill take 150.00.
PostPosted: Thu Jan 24, 2013 8:30 am
I sent you a PM. Thanks, Terry
PostPosted: Fri Jan 25, 2013 3:00 pm
For whatever it's worth, I'm not a fan of the harmonic "dampeners". In doing dynamic prop balancing, I find that many times they cause more vibration for a period of time after engine start, before they settle down, and they make balancing a little more problematic. This goes on with every start after an extended shut-down, and I believe it can amount to a lot more wear & tear on mounts, airframe, etc. over the life of an engine. If you have a lightweight wood prop, a simple steel ring bolted to the flywheel, weighing 11 to 13 lbs., does very nicely for adding additional angular momentum, and will probably be less expensive. You'll get smoother/lower idle, and probably pick up a small amount of additional rpm & usable power. Then get the entire assembly dynamically balanced. That's just my experience & opinion, worth exactly what you just paid for it. 8)
PostPosted: Fri Jan 25, 2013 5:40 pm
John : Where did you get your man hole cover ? With your skills you probably whittled it on your front porch ! BOOM !
PostPosted: Sat Jan 26, 2013 12:51 am
Rich,
I actually bought one from Mark Landoll, then sold it to a friend who needed it before I did. Then I copied it and carved one out on my front porch. ::)
PostPosted: Sat Jan 26, 2013 6:46 pm
Haha. Well, I can prove that the TSA doesn't care about harmonic balances. I'm in Destin Florida with my balancer for Terry.
stevehawley
PostPosted: Sun Jan 27, 2013 6:42 am
I ran my O-360 T-18 with a Warnke prop and a Landoll harmonically balancer for over 25 years. I'm not sure in reduced any vibration but it sure did make the idle at 525 rpm much smoother. A steel ring will do the same at a much lower cost. About 5 years ago a series of small cracks showed up in a curely maple lamination near the hub. I was not overly concerned but watched them carefully. With much regret I removed the Warnke prop and Landoll balancer and replaced the prop witha brand new Sensenich made for the T-18. Everything about the metal prop performance wise is better but if I could, I would still be running the wooden one. I now run the balancer on my Bucker Jungman (180 hp with fuel injection)
Steve Hawley
phred737
PostPosted: Sun Jan 27, 2013 1:07 pm
Lucky! I went through Tucson TSA with a rivet gun and bucking bar ... made it through after extreme scrutiny!
PostPosted: Sun Jan 27, 2013 4:41 pm
That's funny
PostPosted: Sun Jan 27, 2013 5:40 pm
Steve Hawley!!!! How the heck are ya!! Commin Calif way any time soon? Dan
stevehawley
PostPosted: Mon Jan 28, 2013 5:52 am
Dan, I always look forward to seeing your info on the forum. There are disadvantages to being faithful on the forum though! It took years to get the "Go see Cal" ditty out of my head and now it has returned! Most people reading this won't know what I'm talking about but you will. Don't know when I will be back in CA but hopefully soon. Plan on making both S&F and Oshkosh. Maybe will see you at one of those.
Steve
PostPosted: Mon Jan 28, 2013 7:58 pm
Hey Steve, that ornery Rich has got me to mumbling that cal stuff around the house and Gloria says I need help! I am planning to go to Airventure, I Sat here in my Chair and plotted my route just this last Sunday evening. I'm tryin to talk Ira and Dean into goin also and I might have some luck,if not then I will be solo on the southern route I guess....Blessings. Dan
[ Time : 0.100s | 9 Queries | GZIP : On ]
