It is currently Tue Nov 04, 2025 4:59 am
 Post subject: Bearing for jack screw
PostPosted: Thu Jan 24, 2013 3:37 pm
Anyone tried to located a source for the self-aligning bearing on the jack screw? I hope no one is using the standard type - it needs to move a little. Drawing #701 calls for Fafnir K55. 3/8" ID, 7/8" OD, 1/4" Wide. Mine has axial play which of course shows up on the tabs (not good). I've heard some put a nylon shim behind the head of the screw, but would rather get a new bearing. I'm workin hard at all the rest too. Thanks in advance...
Les Krumel,
Albuquerque
stug
PostPosted: Thu Jan 24, 2013 3:54 pm
Les try Aircraft Spruce I think the equivalent bearing is
KS SERIES BEARINGS MS27645-6A
Part # KS6A
Stug
bjwest
PostPosted: Thu Jan 24, 2013 8:15 pm
Les I just got one from Aircraft Spruce. You still need a shim behind the new one, there is about .030 inch axial play in the new one.
Brian
PostPosted: Fri Jan 25, 2013 2:41 pm
Les,
Shimming, usually with a thin disc cut from plastic, has been necessary "forever". A new bearing will not eliminate the small amount of axial play.
PostPosted: Sat Jan 26, 2013 12:11 am
I'm sure Mike has some as well
PostPosted: Sun Jan 27, 2013 8:56 am
I bought a couple from a guy in BC who had a bunch of a/c surplus inventory. That was three years ago. Not sure if he's still around. His company was Aero Dynamic Solutions, I think.
Tony Jensen
aerodyna@island.net
250-956-2233
I have a spare. PM me if interested.
[ Time : 0.188s | 10 Queries | GZIP : On ]
