						 Welcome aboard! Seek out the T-18s at fly ins and airshows that you attend, and see if it's something you might be interested in, then attend some builder's workshops, on Sheet Metal construction, wiring, and the other skills needed. These were not available in the 1960s and 70s when the T-18 first became established, but they are worth your time. Join a local EAA chapter in your area. It will bring you into a group of like minded fliers, and help keep you focused on your project. As Dan pointed out, T-18 (& S-18)s now come in several flavors: 1)  You buy the Plans, and you buy the material, then you get started. 2)  You buy the plans and some sub assemblies, and material, then get started. 3)  You buy a not completed project and finish it. 4)  You buy a Flying T-18 (or S-18) and fly it right away. 5)  You buy a T-18 that has not been flown for a while and needs some work. I did option 5. Good Luck!
						 _________________ Scott Emery EAA Chapter 326 T-18 N18TE
