It is currently Sat Nov 01, 2025 11:08 am
chuck
 Post subject: Tire Pressure
PostPosted: Fri Sep 17, 2010 5:44 pm
Gents,
I know it's been discussed before, however, I can't seem to locate it on the forum. What PSI are you folks using for your tires? I've been questioning whether mine are to low (25psi), I'm noticing rub marks on the inside of the tire, where it appears the brake housing is rubbing on side loads or "heavy" landings.
Chuck Kincer
Chuck Kincer
Richmond, Me
575CK
KIWI
PostPosted: Fri Sep 17, 2010 7:44 pm
Go to Thorplist archive. Go search. Type in Tire Pressure. Go page 5 ? Maybe it was 6 ?
PostPosted: Fri Sep 17, 2010 9:11 pm
I liked mine at 35 psi - it challenged me to kiss the tarmac - having said that, new owner says I had the port tire at 50 PSI.....?????.....must be cuz it always tucked to the left.
chuck
PostPosted: Sat Sep 18, 2010 4:31 am
Well that was easy enough! found several posts.
Chuck
Chuck Kincer
Richmond, Me
575CK
KIWI
PostPosted: Sat Sep 18, 2010 6:25 am
I use a tire that has four ribs and three grooves. I inflate the tire until the outer rib lifts off the floor or inflate until you can stick a 1/4" just under the outside of the tire, what ever the pressure turns ouy to be??.
[ Time : 0.082s | 10 Queries | GZIP : On ]
