It is currently Sat Oct 31, 2026 12:10 pm
 Post subject: Aileron Trim Tab
PostPosted: Sun Sep 12, 2010 12:07 pm
I think JT was more concerned with stick pressures than balance. I have seen Thorps that had a plain stick made out of the 3/4" aluminum tube and Thorps that had a 2 x 4 for a stick grip, this alone would throw off the balance of the controls. I believe the weight od the linear actuator and RAC are about the same. I have flown 1100 hours and had zero problems with detachment, but I think the trim would fall in trail and no flutter. I am under the impression the Frigelli micros are 10MM - 100MM travel and have preset limit switches and cannot be adjusted.
Richard H Woodcock
PostPosted: Mon Sep 13, 2010 9:02 am
The setups discussed here seem far more "conventional" than John Thorp's "lower one flap" method. But, I have a question.
Given a flap control system as is shown on the plans, are there deficiencies in the trim design? What is the advantage of true aileron trim?
Rich Woodcock
N114RW - T18CW
PostPosted: Mon Sep 13, 2010 9:05 am
The per-plans flap-trim system only raises the left wing. If you're imbalanced right wing heavy you're on your own.
[ Time : 0.249s | 11 Queries | GZIP : On ]
