It is currently Sun Nov 02, 2025 5:55 pm
PostPosted: Tue Jun 26, 2012 9:59 am
There has to be a better way to do this ... the masking alone took around 6 hours, painting of course took 30 mins.
Hey motor guys, is there a less time consuming method here I'm missing? Do shops have pre-sized masking and or just old assessories/cylinders they paint over? Surely they do not mask the case like I've done here.
In the end the result is good and what I was going for, but for crying out load what a pain ... I'm only halfway .. this was motor one out of two.
PostPosted: Tue Jun 26, 2012 11:02 am
I don't know if there's a better way, Lee, but your parts look great. Six hours well spent.
PostPosted: Tue Jun 26, 2012 11:18 am
Nice detail work.
Manufactureres and rebuilders don't put that level of detail into a paint job.
PostPosted: Tue Jun 26, 2012 11:25 am
Thanks Dick!
Shipchief,
Yeah, I figured they just assembled and painted them ... one of my pet peaves is paint on gasket/seals/bolts/nuts. I guess I could save myself the work and just build them up and paint them but my hope is to either sell both or hopefully keep one for myself in that case I'd kick myself it were not "detailed" it's a curse sometimes.
davem
PostPosted: Tue Jun 26, 2012 11:48 am
When I paint my engine parts, (in addition to the masking you did) I lay out a strip of masking tape and use a hole punch about 1/2" diameter to punch out a bunch of round tape pieces. Then use those to cover the area around each bolt hole in the case, pan, and accessory case. That way you do not get paint between the bolt and/or washer against the case, which can cause them later to loosen slightly. It doesn't take much extra time to do this, and I think it is recommended by the engine experts.
Dave M
Sacramento
ex-T-18 owner
PostPosted: Tue Jun 26, 2012 12:30 pm
Good advise! Thanks Dave!
PostPosted: Tue Jun 26, 2012 1:30 pm
My engine guy uses stick-on circles you get from Staples to do what Dave says. He also paints the engine after assembly, having partially painted the cylinders (the in between parts) prior. He has pre-made cardboard covers he puts over the accessory holes such as the mags, etc.
PostPosted: Tue Jun 26, 2012 2:25 pm
Thanks Bob .... just walked over to Office Depot ... saved me some punching
PostPosted: Tue Jun 26, 2012 6:36 pm
Lee: Beautiful job ! I would think some of the painting could be done AFTER assembly. Pretty sure that's how Aero Sport Power did my engine. You can see the attention to detail as all the studs have no paint on them. I would have to look at the gaskets, but never really noticed any paint on them ? :-\ 6 hours of masking makes for a show engine !
PostPosted: Wed Jun 27, 2012 9:37 am
Thanks Rich!
I suspect as Bob pointed out that the pros have sets of pre made maskings and or covers.
Here's round #2 .. note the Dave Magaw / Highley recommended "dot" maskings ... as with most things the learning curve played a part here 1 hour to mask the assessory case and sump. The case halves shouldn't take much longer.
[ Time : 0.151s | 10 Queries | GZIP : On ]
