It is currently Mon Nov 03, 2025 8:53 pm
chuck
 Post subject: Fuel Gauge
PostPosted: Mon Sep 06, 2010 12:42 pm
Gents,
What is everyone else using for an analog gas gauge? Mine is junk, sometimes it works, sometimes it doesn't. I have an EI fuel monitor which works great, and would like to have an analog back-up that's consistent.
Chuck Kincer
Chuck Kincer
Richmond, Me
575CK
KIWI
PostPosted: Mon Sep 06, 2010 12:48 pm
I have used a Stewart Warner gage and sender for 26 trouble-free years. Check with hot rod or boat supply shops.
PostPosted: Mon Sep 06, 2010 5:06 pm
Chuck...what type do you have? Sometimes it works, sometimes it don't ? Sounds like a wire problem ? I would tend to check that first, could be as simple as a loose ground. [;)] Do you have access to the sender w/o taking out the tank ? Access cover on top of the fus.?
chuck
PostPosted: Mon Sep 06, 2010 5:26 pm
Rich,
It's a Westach form Aircraft Spruce. This intermittent operation has happened before and it indeed was a loose ground at the base of the sending which was repaired by a local A&P. The Ground wire attach point on the unit seemed a bit "cheesy" from the start and I wouldn't be surprised if that's the culprit again.
Thanks.
Chuck
Chuck Kincer
Richmond, Me
575CK
KIWI
chuck
PostPosted: Mon Sep 06, 2010 5:32 pm
Thanks Bob, I'll check your suggestion out.
Chuck
Chuck Kincer
Richmond, Me
575CK
KIWI
[ Time : 0.083s | 11 Queries | GZIP : On ]
