It is currently Wed Nov 05, 2025 9:37 am
dcuke
 Post subject: which AN bolt for wing?
PostPosted: Thu Dec 16, 2010 7:33 pm
I am starring at the 599 and I am trying to figure out what AN bolt,nut,washer to get for mounting the wing to the fuselage. I see only the the specs for the AVDEL BALL-LOK PIN, but no specs for which bolt to use.
I see an 5-4A on the drawings, but that is way to short to put through the wing/fuselage... besides that, I cannot find any other reference to a bolt. Am I crazy or is it not shown?
Can anyone let me know which bolt to use?
Dean Cuke
Visalia, California
N772DM
KVIS
PostPosted: Thu Dec 16, 2010 8:58 pm
dcuke,
Why don't you just add up the thicknesses of the materials that make up the spar , add the thickness for a couple of washers and look it up on the AN/MS bolt chart?
PostPosted: Fri Dec 17, 2010 12:43 am
Dean,
have a look here
http://thorp18.com/forum/topic.asp?ARCH ... IC_ID=5695
If it's the main bolts I think it's an AN6-25
dcuke
PostPosted: Fri Dec 17, 2010 10:49 am
Great. Thanks.
it looks like the main bolt is AN6-25. nut - 365-624a. washers - 960-6
Dean Cuke
Visalia, California
N772DM
KVIS
PostPosted: Fri Dec 17, 2010 11:06 am
Looking thru my parts catalog, it appears I ordered an AN6-22A bolt.
dcuke
PostPosted: Tue Feb 01, 2011 10:47 am
an6-22a is the correct bolt. 6-25a is just a little too long
Dean Cuke
Visalia, California
N772DM
KVIS
Fla-T18
PostPosted: Sun Apr 29, 2012 11:24 am
Thanks for this post, I was going to ask about the very thing. I will be ordering the bolts.
stug
PostPosted: Tue May 01, 2012 7:07 am
It you were interested in the Ball-loc pins they are still available from Avibank.
The Australian distributor quoted me $42.39AUD each on the basis of a minimum order of 11.
Thats for the BL S 6 TA 17 S that is called for in the plans. That is one expensive bolt and also requires a 6-9 week lead time on manufacture.
[ Time : 0.094s | 10 Queries | GZIP : On ]
