It is currently Mon Nov 03, 2025 4:18 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: New member/new owner
PostPosted: Wed Apr 18, 2012 4:58 pm
2751 is back in the air! First test flight went pretty good all numbers in the green. The only squawk is the front seal is leaking a bit.
I
PostPosted: Wed Apr 18, 2012 5:03 pm
Good job ! I saw someone change one of those front seals. Quite the operation. Heat the seal in hot water. Lube it up and use a "special spoon" to stretch the seal over the hub into position. The only dance I know is the Funky Chicken ! O0
PostPosted: Thu Apr 19, 2012 12:23 am
Lou;
Pics!!
I'm close to first flight in N883FF.
I see Bruce F has the prop back on his T-18C. Maybe I can get a ride for familiarization.
Maybe in a couple of days I'll get the time to finish the condition inspection, and I'll be off!
PostPosted: Mon Apr 23, 2012 12:59 pm
Three hours and so far so good. The front seal is leaking and will need to deal with that.
PostPosted: Mon Apr 23, 2012 1:28 pm
Classic is still making fuel tanks as well.
PostPosted: Mon Apr 23, 2012 7:41 pm
Hi Lou, I installed my crank seal, it's a cakewalk. Put a sandwich bag over your prop flange, you will find it very slick and the seal just glides over. Put the seal in some hot water from your coffee thermos for a minute and it will be more pliable, it is a very simple process the darn things are just glued in..Dan
Jeff Blanton
PostPosted: Mon Apr 23, 2012 8:37 pm
I just went through this. If you have a machined grove in the case you use the one piece seal. If not you use the split type. The one piece seal has a raised part to help keep it in the case. Here is the lycoming SL
Jeff
SI1324C.pdf [127.66 KiB]
Downloaded 833 times
PostPosted: Wed Apr 25, 2012 11:23 am
here's a few pics of the install.
[ Time : 0.114s | 10 Queries | GZIP : On ]
