It is currently Tue Nov 04, 2025 11:51 am
flychris
 Post subject: Dumb Question
PostPosted: Wed Mar 28, 2012 10:41 pm
Ok so i just noticed that some thorps have a flat belly aft of the flaps and some are sorda gupy looking like mine. Whats the differance? ???
 Post subject: Re: Dumb Question
PostPosted: Thu Mar 29, 2012 5:18 am
Check the plans. The Thorp has a flat bottom on the fuselage. Need to see a picture. Don't know of any gupy lookin' Thorps out there.
flychris
PostPosted: Thu Mar 29, 2012 7:21 am
here is a pic of min without the wing when i just bought it.....
It looks like this one you can see how it doesnt go strait back it rounds out sorda late i guess...
stug
PostPosted: Thu Mar 29, 2012 7:40 am
Std T18 plans have the curve starting around the rear spar attach point.
PostPosted: Thu Mar 29, 2012 1:57 pm
Looks normal to me, The S18 is 5" longer than a T18 maybe this is what you are seeing or it could be an optical contusion!
PostPosted: Thu Mar 29, 2012 2:32 pm
Probably parallax ?
PostPosted: Thu Mar 29, 2012 7:18 pm
The second photo is my airplane N18JF, what you can't see in the photo is there is a wing to body fairing that starts about where the stripes on the fuselage start and is probably causing the illusion by hiding the curve of the fuselage.
PostPosted: Thu Mar 29, 2012 7:40 pm
Bruce, you have a fine looking Thorp ....Dan
PostPosted: Thu Mar 29, 2012 10:37 pm
Could be me, but doesn't 587's windshield extend a little lower than I am use to ? Not that there is anything wrong with that ! In fact it looks like an increase in visibility ! I like more visibility from the inside out !
PostPosted: Fri Mar 30, 2012 5:22 am
Over the years the roll bar was raised 3/4". Early builders installed a block to raise the height.
davem
PostPosted: Fri Mar 30, 2012 9:34 am
Here is a side view of a pretty stock built T-18--N18GR, first flew in 1978. Bill Cordoza took this picture of it on my first flight in it last year. Not very much guppy looking...
Dave M
Sacramento
ex-T-18 owner
PostPosted: Fri Mar 30, 2012 11:25 am
Is that the "T18 Grin," Dave?
Like the RV Grin, only smilier?
PostPosted: Fri Mar 30, 2012 3:19 pm
T-18 Grin .....Tin Grin!
That's waht we used to call a smile with braces on the teeth. :D
I really like the picture. The Whole picture, including the hangar, where I see that things get done.
Hopefully I'll have that grin this weekend.
[ Time : 0.155s | 11 Queries | GZIP : On ]
