It is currently Mon Nov 17, 2025 11:16 pm
mgon
 Post subject: Project questions
PostPosted: Fri Feb 03, 2012 9:30 am
I'm finishing up my build and have a few questions.
Aileron hinge pin. What is the common way to retain or to
safety the pins?
Cowling. Is a support normally used at the cowl side exit (fiberglass cowl)
or are rigid enough?
I will try and post pics.
Mark
File comment: Sorry, not the best pics
 Post subject: Re: Project questions
PostPosted: Fri Feb 03, 2012 10:42 am
Mark,
Hope these sketches help, there are a few ways to secure the aileron hinge pins, I like this one the most. You could also secure them in the same fashion to the upper edge of the wing skin. Regardless you want the pins coming in from the center of the aileron and inserted towards the outside. The other way does not work so well (at least that was my experience).
PostPosted: Fri Feb 03, 2012 12:27 pm
Nice airplane, Mark! How about some more pictures of the build and/or the finished product?
d
PostPosted: Fri Feb 03, 2012 6:00 pm
I wish I had a photo of how I did it, but I got the idea from Dan. I used a scrap piece of hinge and secured the "bent" portion of the pin to the aileron beam, thru the outer bolt. I did it for the ailerons and the trim tabs on the hor. tail. No safety wire or drilling required ! Makes for a clean install ! The only safety wire I used for the control surfaces was for the top and bottom rudder bolt.
PostPosted: Fri Feb 03, 2012 8:53 pm
Sure looks good Mark, If it's not an imposition post a few more pics when you get the time. That piece of hinge does work pretty good don't it Rich, good thing we swapped ideas during our builds it made things move right along. Also, it is good inspiration for those long hot summer days and cold winter evenings of building. Finish er up Mark, it's obvious that you are going to deserve all the good times to come, it looks like you really worked at it....Dan
dcuke
PostPosted: Fri Feb 03, 2012 9:01 pm
I also took Dan's idea for the aileron hinge. Works like a charm and looks clean (no need to safety wire).
PostPosted: Fri Feb 03, 2012 9:25 pm
That little bit of hinge works...BADA BING, BADA BOOM ! Thanks for the idea Dan ! Now can you tell me how to turn lead into GOLD !
mgon
PostPosted: Fri Feb 03, 2012 11:06 pm
Thanks for the drawing Lee, I thought it would have to be done in such a way.
Also using a little piece of hinge section for retention is a great idea.
And thanks for the nice comments.
I hope to schedule the DAR shortly, few more items to finish up.
I'll post some more pics.
Mark
PostPosted: Sat Feb 04, 2012 6:56 pm
Wow!! That's clean!!! Like the cockpit, like the paint, love the simplicity, the workmanship is show stopping. Well Done Mark, well done.......Dan
PostPosted: Sat Feb 04, 2012 7:24 pm
I think the DAR will be impressed !
[ Time : 0.124s | 11 Queries | GZIP : On ]
