It is currently Tue Nov 03, 2026 1:38 pm
 Post subject: Prop and Spinner wanted
PostPosted: Tue Dec 13, 2011 9:40 pm
Looking for a good prop for an O360, ideally with a Thorp-sized spinner.
Dick Wolff
edwolff @ brucetelecom dot com
PostPosted: Tue Dec 13, 2011 11:27 pm
O0 AD prop. BN-3 spinner kit from Spruce...made for the Lycoming and fits the cowling, (you have to do the cut outs). If you need a crush plate and extension...Saber products. He even has the correct prop bolts. This is the package I used and have been very happy. Assuming you are looking for a wood prop ? ::) The spinner has tooling marks on it and will need polishing. Spruce can do the polishing for a price.
chuck
PostPosted: Tue Dec 27, 2011 5:43 pm
Dick,
I have a Sensenich 70/77 1/2 bolts with spinner and bulkheads, has about 100 hours on it. I don't know if would fit an 0-360 it came off of my 0-320.
Chuck
PostPosted: Fri Dec 30, 2011 9:57 pm
Dick, check with Dean Cuke on that prop for the 360, I believe he has one in his Garage. Dan
PostPosted: Tue Jan 03, 2012 9:30 pm
Hi Dick, I gave Dean your email,he will mail you in regards to the prop."....Dan
PostPosted: Wed Jan 04, 2012 7:27 am
320's and 360 Lyc's have different prop bolts unless someone has changed the flange spools . The 320 has 7/16" bolts and the 360 has 1/2" bolts and will not interchange.
davem
PostPosted: Wed Jan 04, 2012 10:37 am
Depending on the model, some O-320s have 3/8" bolts lugs--the OD of the lug is otherwise the same as the 7/16" ones. I had one of each up until a couple of months ago.
Dave M
dcuke
PostPosted: Wed Jan 04, 2012 11:08 am
@Dick,
I sent you an email about the prop that I have for an O-360. I also attached some pics of it.
PostPosted: Fri Jan 06, 2012 8:05 am
Dick, This is worth looking into. The spinner alone sells for $425.
http://www.barnstormers.com/listing.php?id=621038
PostPosted: Fri Jan 06, 2012 4:30 pm
Nice... but isn't 76" a bit long for a Thorp?
PostPosted: Fri Jan 06, 2012 6:23 pm
Yes it is Dick, sorry didn't even look at the size of the prop .. the spinner would work on a thorp very well though.
N89BJ
PostPosted: Mon Jan 09, 2012 11:24 am
Rich,
Just noticed your prop in the strobe light picture. So is your AD prop painted like a Hartzell or are you running a metal prop? Thanks.
PostPosted: Mon Jan 09, 2012 6:41 pm
Nope...AD wood prop painted gray, white tips and black on the back side. More than more person has asked me if it was a metal prop ! :o They don't know it's wood until I tell them. :))
N89BJ
PostPosted: Mon Jan 09, 2012 9:54 pm
Rich, very nice.
Byron
PostPosted: Mon Jan 09, 2012 11:36 pm
Hey Rich, now I got several folks convinced that my prop is Metal, if you keep tellin folks they are wood, it's going to completely undo my story on organic aluminum!!! Dan
[ Time : 0.223s | 13 Queries | GZIP : On ]
