It is currently Tue Nov 18, 2025 2:42 am
Derek Fritschle
PostPosted: Mon Oct 10, 2011 7:12 pm
Here are some pictures of my T-18 rebuild/refurbish project. I acquired the project in early January 2011 after the previous owner had a landing mishap and banged up the wings and bent the gear. Since the plane had its first flight nearly 25 years ago I am taking the oppurtunity to not only repair the damage but also make some updates/upgrades.
Image Insert:
Fuselage before
Image Insert:
My First Assembly Ready to Rivet
Image Insert:
All Riveted up
Image Insert:
Roll Trim Tab Installation
Image Insert:
Center Section Re-Skin Nearing Completion
Image Insert:
Back on Straight Legs
Image Insert:
The Most Complete the A/C has looked so far. (Looks can be very deceiving.)
Derek Fritschle
N27DW
618-839-1522
OLY
PostPosted: Mon Oct 10, 2011 7:37 pm
Looks like you are doing a fantastic job ! Having never been on the repair end of a project my hat is off to you !
PostPosted: Mon Oct 10, 2011 8:08 pm
Looking great Derek! Looks like KY dam 2012 is within reach!
PostPosted: Tue Oct 11, 2011 12:25 pm
So, how many Thorps are there in Olney, IL?
Inquiring minds want to know.
Derek Fritschle
PostPosted: Tue Oct 11, 2011 12:51 pm
Current count (projects included):4 in Olney, plus one 25 mi. away in Vincennes, IN. It won't be long and an entire squadron of RVs won't stand a chance around these parts.
Derek Fritschle
N27DW
618-839-1522
OLY
cgifly2
PostPosted: Sat Dec 10, 2011 12:12 pm
Dereck Project looks good! I am in the same boat ...errr plane. A complete rebuild of a 30+ year old airplane. Was wondering did you replace the firewall? Or just real good at cleaning? I am right on the verge of wanting to replace mine along with the top header skin. Both just have to many holes that dont belong and I really want to change the windshield trim to (non trim) flow into the skin. But am wondering if any who have done it feel it was worth it?
Skeet
PostPosted: Sat Dec 10, 2011 8:25 pm
Skeet: It is worth it...IMHO. I tried to attach pics of my "trim less" windshield but could not figger out how to attach the pics from my gallery ? Bob Highley ( I think it was Bob ? ) has a tool to make the radius bend on the skin. He has pics also of the tool and the bend for his windshield.
cgifly2
PostPosted: Sun Dec 11, 2011 2:09 am
Well if you ever figure out how to do the pics please do as you know the saying. I wont go on with a thousand words ;D
Skeet
PostPosted: Sun Dec 11, 2011 3:19 pm
A couple of shots of the above topic:
cgifly2
PostPosted: Sun Dec 11, 2011 3:35 pm
Thanks for the pics Bob. I have 2 questions. 1 What did you use to bolt the windshield on? 2 And do you think it would be possible to use an English wheel on that skin before mounting it?
PostPosted: Sun Dec 11, 2011 5:27 pm
I installed my windshield pretty much the same way Dan Eggleston did. Installed brackets to the inside frame, attached the weather strip and then pushed the glass up against the fus. skin and tightened the brackets. I think I only used 4 screws on the sides to attach the glass to the skin. Also no trim strip was installed.
cgifly2
PostPosted: Sun Dec 11, 2011 8:50 pm
Got ya thanks ;)
PostPosted: Wed Dec 14, 2011 9:02 pm
Skeet,
I used a .040 strip with nutplates for the area behind the instrument panel. The screws aft of the panel are secured to the cockpit trim piece with stainless nuts.
Derek Fritschle
PostPosted: Fri Dec 30, 2011 8:55 am
Here is a progress report on my project. It has been pretty slow going due to lack of time but hopefully the next few months are better. As you will see most of my recent progress has been adding conveniences that are standard on most t-18s. The next item on my agenda is replacing the boot cowl so I can tuck my windshield inside.
File comment: Another vital access panel
File comment: Here is a shot with the removable panel in place.
File comment: This is a mod I had not planned on doing, but after a couple of head first trips down towards the rudder pedals I would recommend it to anyone.
Derek Fritschle
N27DW
618-839-1522
OLY
PostPosted: Fri Dec 30, 2011 12:31 pm
Looks great Derek!
I had better step it up ... you're a bit passed me I think!
[ Time : 0.134s | 11 Queries | GZIP : On ]
