It is currently Thu Oct 30, 2025 3:10 am
admin
 Post subject: SIKAFLEX INFO
PostPosted: Wed Oct 26, 2011 12:26 pm
Steve said I should very carefully read the info at the Sika website for the product. He recommended to use SIKA 209 to cover the plexi to make it opaque, SIKA 226 for cleaning the frame, and SIKAFLEX 295UV BLACK for gluing the canopy on, trying to get at least 1/8" space between the canopy and the frame.
He recommends that all structural bonding be done with the BLACK urethane as it has much better UV properties. If needed, one can make fillets with WHITE urethane over the black stuff, 295UV comes in black and white colors.
Most places I called would only sell a case of 12 10-ounce tubes of the 295UV. Again, Steve came to the rescue... Jamestown Distributors @ 1-800-423-0030 will sell you individual quantities. Pricing: about $12US for a tube of 295UV black or white, $31US for a pint of 209 and $11US for a pint of 226. So that's what I ordered, one tube each of black and white, one pint of 226 and one pint of 209. One could say I am now committed ;-)
*** admin posted for Hurant Kariban ***
Forum Administrator
PostPosted: Wed Oct 26, 2011 12:42 pm
Dang - back when I used to peddle the stuff, a 10.5 oz toob of Sneekyflex was out the door for 3.5 jeters. It's the best stuff on the market tho - a lot of floatable boatables remain as such due to that product.
 Post subject: Re: SIKAFLEX INFO
PostPosted: Thu Dec 15, 2011 10:20 pm
Chalkie Stobbart was the first to announce that he had used SIKA to install the windshield on his RV-6.
http://www.vansairforce.com/community/a ... 67327.html
This link is from the VANSairforce forum. I used SIKA to install the windshield, canopy and skirt on my RV-8.
Search the VAN's forum archive, also check out Chalkie Stobbart's original article.
http://www.rvclubsa.com/rvsa_article_2_canopy_glue.htm
This is a very tried and accepted method...now. At first it was contentious, to the point that people would tell you that you cannot do it (like they had the authority to make you stop or something?)
The advantages are:
Ease of original installation.
Reduced likelyhood of cracks, due to no fastener holes in the plexi.
Reduced optical distortion due to long low stress SIKA joints instead of puckered point loads at rivet/screw fateners.
Disadvantages:
Heavier, especially if you use too much SIKA
More expensive (those SIKA products aren't cheap)
BobMoe
PostPosted: Fri Dec 16, 2011 9:10 am
Here's a limk to some additional info.
http://wiki.matronics.com/wiki/index.ph ... our_Canopy
http://www.rv8.ch/article.php?story=2005061620363366
Derek Fritschle
PostPosted: Tue Jan 24, 2012 9:42 pm
The task of replacing the boot cowl on my rebuild project has lead me to contemplating how to attach the existing windshield to the boot cowl. I am not pleased with the hole spacing the builder chose to attach the two and not wanting to drill a bunch more holes in it. I am considering using something like Sikaflex to adhere just the boot to the windshield (because of canopy to windshield fitment the trim piece around the roll bar is vital). Any advice on techniques, how to hold it in place while the stuff sets, words of caution, would be greatly appreciated.
Derek Fritschle
N27DW
618-839-1522
OLY
PostPosted: Tue Jan 24, 2012 11:00 pm
Derek, around the boot cowl still requires fasteners even if you use sikaflex. Gary told me he tried all sorts of clamping techniques but in the end he needed the screws to hold it in place while the goo cured.
PostPosted: Tue Jan 24, 2012 11:07 pm
Not sure where the "boot cowl" is ? Lower front for the windscreen ? Any relation to "Hoot Mon, Hoot Mon ?"
Copy of S-18 windshield and canopy trim strips 002.jpg [ 996.22 KiB | Viewed 12167 times ]
[ Time : 0.167s | 13 Queries | GZIP : On ]
