It is currently Wed Nov 05, 2025 8:05 pm
BobMoe
 Post subject: Push pull tube
PostPosted: Tue Oct 18, 2011 1:15 pm
I have a set of push pull tubes with the ends Swagged/narrowed/reduced to 1/2" and I was wondering how this is done.
Stephen Peirce
PostPosted: Tue Oct 18, 2011 1:51 pm
Tube swage process is done mostly with aluminum, copper or thin wall steel. Can be accomplished on a tube or a solid rod and reduce the outside diameter down to a specific diameter using a die. Cold tube swaging is relatively quick, inexpensive and chipless.
Stephen R. Peirce
S/N#078 Ph 256-461-0233
Rocket City
Huntsville, Alabama
[ Time : 0.323s | 11 Queries | GZIP : On ]
