It is currently Tue Nov 04, 2025 7:31 am
dcuke
PostPosted: Sun Apr 17, 2011 7:30 pm
I am trying to figure out the length of the rudder cables for a standard t-18. I am looking at the #518 to determine length, but I cannot find anything here. Is there a standard length for the cable or do I just need to measure for myself?
Dean Cuke
Visalia, California
N772DM
KVIS
PostPosted: Mon Apr 18, 2011 8:56 pm
Dean,
Just did my rudder cables. I measured twice and got 150.8 inches total, hole to hole, including fittings. Best as I can tell, math from the drawings says about the same. I really suggest you measure your own, since everyone's can be a little different. Tolerances have a way of stacking up, and the turnbuckles are limited to maybe +/-.75" range (?) I used electrical wire for measurements (less stretch than string) and averaged R & L together.
Hope this helps, Les.
dcuke
PostPosted: Tue Apr 19, 2011 3:28 pm
Thanks Les for the info
Dean Cuke
Visalia, California
N772DM
KVIS
PostPosted: Mon Oct 03, 2011 9:49 am
Request - can someone post a photo of a typical "notched right brake pedal" sometime. (For clearance with the tank mount.) I can't seem to find one in the NLs or the forum albums.
Thx. My brake pedal shows evidence of contacting at the bottom, as well as at the top.
_________
PostPosted: Mon Oct 03, 2011 10:26 am
Dick,
I don't have a pic handy but even if I did it would be pretty anti-climactic. You're going to end up cutting a 2 inch square out of the upper left hand corner of the pilots side right hand brake pedal.
PostPosted: Mon Oct 03, 2011 10:31 am
Here you go Dick.
Stephen Peirce
PostPosted: Mon Oct 03, 2011 2:11 pm
Here is a pic that I located.
Image Insert:
Put File Caption Here
Stephen R. Peirce
S/N#078 Ph 256-461-0233
Rocket City
Huntsville, Alabama
PostPosted: Mon Oct 03, 2011 2:56 pm
Pretty darn good drawing Lee ! Reminds me of my Junior High School Days during one of my Mechanical Drawing Classes trying to make a 3-D drawing of a block of wood using a pencil and a T-square on a piece of poster board! You got a deduction in your final grade for every erasure ! [:(] This was 1965 and computers were still an idea in Bill Gates garage ! [8D]
PostPosted: Mon Oct 03, 2011 4:19 pm
Steve ... that pic looks awfully familiar [;)]
PostPosted: Mon Oct 03, 2011 4:51 pm
Yeah, nice sketch. That's pretty much what I figured for contact at the top of the pedal. BUT ... What about the bottom edge? Move the pivots back, I guess.
Image Insert:
Image Insert:
_________
PostPosted: Mon Oct 03, 2011 4:59 pm
It may be possible the pivot points are not in the correct location ? It may be possible the anchor points on the floor are not in the proper location ?
PostPosted: Mon Oct 03, 2011 5:32 pm
Looks like your pedals were moved forward to accommodate a tall fella, not uncommon.
PostPosted: Mon Oct 03, 2011 7:24 pm
The Tank supports have to be relieved for pedal room, then a doubler is riveted to the support to stiffen it up. its easier when you have the support out of the plane when the build is happening. Mike archer Informed me of this when I was in the middle of the build, had a sketch added to the drawing packet......Dan
PostPosted: Mon Oct 03, 2011 7:49 pm
That's another way to solve it but the vast majority of Thorps out there do not have the notched tank support.
I think in Dick's case since he does not fall into the "tall" category (sorry Dick) he could move the pedals back to the per-plans position and cut a notch in his pedal. At least that seems like the less invasive route.
PostPosted: Tue Oct 04, 2011 3:26 am
Will measure. Makes sense.. I understand that Bill Cox was a pretty big dude.
_________
[ Time : 0.133s | 11 Queries | GZIP : On ]
