It is currently Sun Sep 14, 2025 8:18 pm
Pipercolt
PostPosted: Tue Jan 14, 2025 8:00 pm
I desire to not install the rudder cables in the tunnel. The stabilator trim and flaps will be electric and want to make the center tunnel smaller so there is more room in the cockpit and desire to run the rudder cables outside of the seats also. Any information and/or drawings of this rudder pedal modification and the creation of a smaller rounder center tunnel? Thank you so much for any response. Tom
PostPosted: Thu Jan 16, 2025 8:48 pm
I think that mod may be somewhere in all the newsletters, but I dont know where. Hopefully it is. Here is a link to all the newsletters. Happy hunting. Sorry I cant point you to the exact newsletter.
http://thorp18.com/index.php?option=com ... Itemid=159
Pipercolt
PostPosted: Fri Jan 17, 2025 4:10 pm
Thank you so much. I will start to look for the information.
PostPosted: Fri Jan 17, 2025 8:29 pm
I spent a few minutes looking through the newsletters and I couldnt find anything. If you are successful in finding a write up about it, please post it back here. Good luck
Pipercolt
PostPosted: Sat Jan 18, 2025 7:14 pm
Thank you for looking. I see in Newsletter #73 page 17 a letter from a builder that states " I outboarded the rudder pedals like Bob Dials's drawing." so there is a drawing out there. Anybody have any info about Bob Dial? Thanks.
PostPosted: Tue Jan 21, 2025 12:35 am
I believe that Gary Green had posted photos of his installation of outboard rudder cable on the forum. The search function is your friend 8)
Pipercolt
PostPosted: Wed Jan 22, 2025 12:35 am
Bruce - Thank you. I searched some more but still have not found anything about outboarding the rudder cables. I thought there would be tons of info on this subject. I will continue to research the subject. Thanks again. Tom
PostPosted: Wed Jan 22, 2025 12:49 pm
See newsletter #47 please ...
http://thorp18.com/thorp_newsletter_archive/NL47.pdf
PostPosted: Wed Jan 22, 2025 3:14 pm
Incidentally, I have the Doc’s plane referred to in this newsletter.
It is a round back. One the my future projects.
Pipercolt
PostPosted: Tue Feb 11, 2025 11:41 pm
Thank you so much. That is very helpful. I will keep everyone up to date as to how I put these cables in.
PostPosted: Mon Feb 24, 2025 9:26 am
Guys,
The builder of my plane, Fred Gindl was a good friend of Bob Dial's and he had a lot of input from Bob. My plane (Serial #558) has the outboard rudder cables. It follows the drawing fairly close except for the pulleys at the dash. My plane has a fairlead there instead of a pulley. The side of the plane from the firewall to the seat back is pretty much a straight run so a fairlead works well. From this fairlead, the cable is within a 1" x 2" enclosed cover running from the dash to the seat back. Just behind the seat back there is a pulley set. My baggage floor is raised up and this first pulley set is just under it. Hope this helps.
Regards,
Rv3maker
PostPosted: Wed Feb 26, 2025 11:57 am
Jim Mantyla wrote:
Guys,
Regards,
We believe you . . . but pictures please! ;-)
Rob
RV-3 SN 45 (project)
RV-6A SN 24654 (flying)
KEWK
PostPosted: Thu Mar 06, 2025 9:46 am
I have tried to upload pictures bit the system won't allow it, or something has changed since the last time I sent pictures. If you can send me your email address, I will send directly to you.
PostPosted: Thu Mar 06, 2025 12:22 pm
Sorry about the image issue Jim .. this has been addressed .. please try again,
PostPosted: Fri Mar 07, 2025 10:34 am
Guys,
I tried again and it looks like a couple got rotated 90 degrees. Starting from the front there is a shot of the cable from the pedal to the fairlead at the dash. the second is the cover over the cable. The third is a shot under the baggage area looking forward from the battery access hatch. The last is the shot of the cable going backwards towards the tail.
hope this helps.
Regards,
[ Time : 0.108s | 11 Queries | GZIP : On ]
