It is currently Sun Nov 02, 2025 11:26 pm
 Post subject: Re: elect. flaps
PostPosted: Wed Aug 07, 2024 4:10 am
Build it in off center so you can service it. It will also clear any future autopilot actuator.
Rv3maker
PostPosted: Wed Aug 07, 2024 12:50 pm
Tony28031998 wrote:
Hello!
Anybosy has updated pictures, dimensions of cables or any other info for the install? I have bought the firgellli actuator and I am ready to build the system, but I want to see what everyone has done.
Thanks!
Tony
Following. Can you post the Firgelli actuator p/n you are using. Keep us posted . . some of us will be following you on this mod. ;)
Rob
RV-3 SN 45 (project)
RV-6A SN 24654 (flying)
KEWK
PostPosted: Thu Aug 08, 2024 8:42 am
Tony,
If you look at this thread in it's entirety I think you have what you need .. the attach from the actuator to the flap cables is captured early on (3/8 Bolt, bushings, 1/8 alum stock, 1/4 Bolts, AN115 shackles, and cable thimbles and sleeves. Later on you see the attach from the airframe to the actuator (1" angle, 3/8 Bolt)
Lee
[ Time : 0.117s | 9 Queries | GZIP : On ]
