It is currently Sun Sep 14, 2025 1:46 pm
hjubm2
PostPosted: Thu Aug 24, 2023 9:32 pm
Looking for some info here. My aircraft went in for it's annual inspection and they grounded it due to a problem with the bearings on the crank shaft. I've been quoted between AUD$25k to 45k to fix it so due to that (& not being able to find a part life engine in Australia) I've been considering upgrading to an O-360 as the extra bit of power would be helpful since I operate mostly out of short farm strips.
So the question I have is how much work/changes would be needed to fit a 360 instead of a 320 and is there a certain model I should be looking for? The current engine in the aircraft is a wide deck O-320-E2A.
Thanks guys
PostPosted: Fri Aug 25, 2023 4:54 am
It should only be a change in the baffles as the O-360 is a bit wider. The case is the same. Also, the O-360 uses a larger carb.
PostPosted: Fri Aug 25, 2023 12:12 pm
Do not get an angle valve as they will not fit under the cowl. The engine is also heavier which will require some W/B offset.
hjubm2
PostPosted: Mon Aug 28, 2023 12:51 am
Tha ks for the replys guys, all useful information. I'll keep an eye out for a decent 360 now since it sounds fairly straigh forward.
[ Time : 0.351s | 11 Queries | GZIP : On ]
