It is currently Tue Nov 04, 2025 8:34 am
motoflightguy
PostPosted: Tue Aug 30, 2022 5:18 pm
Has anyone here installed a landing light in the leading edge of the wing? I just bought a T18 project, and I will be rebuilding the left outer wing, and I would like to install a landing light while I'm doing it. I was unable to find any examples. It seems like the best approach would be to add an extra nose rib with the correct spacing for the light, and put a plate between the 2 ribs for mounting. Any advice?
New Thorp Project Owner - N85FT
http://www.youtube.com/motoflightguy
motoflightguy@gmail.com
PostPosted: Tue Aug 30, 2022 8:51 pm
Mine shines through the gap cover between the inner and outer wing panels. It’s a 2” motorcycle light I got from super bright leds that cost less than $50 each. One on each side mounted sideways to what they intended so it’s stays on the inner wing rib.
motoflightguy
PostPosted: Wed Aug 31, 2022 7:22 pm
Yeah I do like how clean your setup is Dave. Upon thinking about this more, I might skip trying to put one in the leading edge and go another route
PostPosted: Wed Aug 31, 2022 7:35 pm
try the lights in the opening of the cowl inlets. They work great and don't effect the cooling.
PostPosted: Wed Aug 31, 2022 8:38 pm
I have the landing/recognition lite in the left outer wing . For some reason I can not upload pics from the pic/doc files on my computer . I got the info with detailed instructions ,including drawings and a materials list from the old News Letters . Remember those . I made a copy of that article that is about 5 pages long . I do not remember who drafted the article , but maybe Lee Walton does . Speaking of Lee , hey Mr. Administrator why can't I upload data that had been done in the past ? I get the "Red Message at the top of my reply that sez "Unable to upload " Blah , blah , blah .
If you still want info and pics of my light and the article email me and I'll send it to you at great time and expense ! RB OUT .
rx115@cox.net
NX115RX
pmandel
PostPosted: Thu Sep 01, 2022 9:12 am
Mine are in the wingtips. Work great. Thanks probably go to Lee Walton since this was his wing. I don't think I have a pic of what's inside, but Lee might know what it is.
Philip Mandel
N118BC
S/N 957
Beaverton OR
motoflightguy
PostPosted: Thu Sep 01, 2022 3:54 pm
Yeah I have seen the posts from Lee on that setup. How does it work as a landing light for actually landing at night? Does it throw a good amount of light? Not aimed down too far?
MartyG
PostPosted: Fri Sep 02, 2022 9:37 am
I have leading edge lights in both wings. I didn't build it though so I can't be much help on that end, but I did replace the lights with the "Double Spotlight" from Flyleds.com and I also used their wig-wag switch. They are incredibly bright and use very little power.
Marty G
N50LE
YouTube Channel
martygrosse@yahoo.com
motoflightguy
PostPosted: Fri Sep 02, 2022 4:18 pm
That's actually why I was thinking about it. I have a spare Flyleds Double Spot that I was going to install. But I think i'll just make the wing rebuild a little simpler by not doing a leading edge light and figure out a wing tip solution later.
pmandel
PostPosted: Thu Sep 08, 2022 10:50 pm
The light is awesome. Aiming is up to you, adjustable. Jump into this night landing video at the 7:30 point. Watch the runway markings and "31L" light up:
https://youtu.be/WRaDsFm6Eg0
Philip Mandel
N118BC
S/N 957
Beaverton OR
[ Time : 0.090s | 10 Queries | GZIP : On ]
