It is currently Tue Nov 04, 2025 3:37 am
Ptbob484
 Post subject: Exhaust Hangers
PostPosted: Thu May 05, 2022 8:47 pm
Does anybody have a good idea for exhaust hangers? I saw this setup but don't know what kind of rubber to use.
 Post subject: Re: Exhaust Hangers
PostPosted: Sat May 07, 2022 1:19 am
Here's one implementation, it's a heavy woven material like a fire hose. Is it a good idea? I don't know but as far as I can tell from going through the logs it's been on the airplane since day one and the airplane has been flying for the last 52 years. It's attached to the A frame with 2 adel clamps
PostPosted: Sat May 07, 2022 7:02 am
I don't know where I found them now, but I have a small spring that hangs from the engine mount and connect to the exhaust. Spring attaches to an adel clamp from the engine mount.
Ptbob484
PostPosted: Sun May 08, 2022 7:08 pm
Thanks guys! Really appreciate the help!
PostPosted: Wed May 11, 2022 6:55 am
I used exhaust hangers I bought from NAPA. They are this style: https://www.amazon.com/Walker-36274-Exh ... 9WJ6&psc=1
I cut my first set down so they were mounted vertical but I didn’t like the vibration being transmitted to the airframe. I mounted the new ones without cutting and hung them so they curve down. The vibration was greatly reduced.
PostPosted: Sun May 15, 2022 8:43 pm
Guys
I used pieces of automotive serpentine belts. Got them for free at a local garage.
PostPosted: Mon May 16, 2022 9:41 am
Hi Guys,
Mine is like the photo, but using stainless steel shim stock. Perhaps .025” thick. Stainless is low conduction, heat proof and shouldn’t need replacement. In engineering it would be called a “flexure”. Relatively holds things in place in all but one direction. Just be sure it has smooth edges. Wouldn’t recommend aluminum.
Les
[ Time : 0.084s | 8 Queries | GZIP : On ]
