It is currently Sun Nov 02, 2025 6:44 pm
jsanders
 Post subject: C wing dihedral
PostPosted: Thu Jun 02, 2011 3:55 pm
If I am reading Sunderland drawing #101L correctly the dihedral angle should be 7 degrees. Correct me if wrong. However when I bolt the 215 and 315 fittings together, I measure 4.1 degrees. Need some comments and info. from C wing builders.
Jon Sanders
Jon P Sanders
PostPosted: Thu Jun 02, 2011 4:38 pm
Are the fittings bolted to the spars? How are you measuring the degrees? the spar fittings are tapered, you would have to measure it along the bolt line. I made a 7 degree angle and clamped it to the spars to maintain the 7 degrees,
Dihedral gives the plane stability and keeps the wingtip from hitting the ground when you ground loop. I would think 4 degrees would be OK but not ideal, the plane would be a little unstable, probably would fly like a RV.
jsanders
PostPosted: Thu Jun 02, 2011 6:42 pm
Bill thank you, was hoping you would jump in on this with your no nonsense approach. No the fittings are not bolted to the spars. I had locked in on the 215 profile and ignored the 315 taper. I leveled the top of 215 in a vise then placed the smart tool on top edge of the 315. Just did it again this time I used the hole line in the 315, it came out 6.9 degrees. I like the idea of the angle jig, will use it.
Jon Sanders
Jon P Sanders
[ Time : 0.264s | 11 Queries | GZIP : On ]
