It is currently Wed Oct 29, 2025 7:20 pm
PostPosted: Wed Dec 23, 2020 7:46 pm
I just installed hinged landing gear fairing on my flying T18. I installed them with the wheel pants on. It is doable, but man, that's a real pain in the backside to get those hinged fairings installed. I will not be removing those things unless I absolutely have to.
Of course my old upper cuffs do not fit anymore, so I may try and make my own before I break down and buy some from Thorp Central.
TonyNZ
PostPosted: Thu Dec 24, 2020 3:14 am
Images: 8
I looked at doing that and decided I couldn't figure out how to get the hinge wire in.
Ended up using 5 aluminium pop rivets' up trailing edge, easy to drill out if need to get fairing off.
Have fun.
Tony Schischka
ZK-VMS
PostPosted: Thu Dec 24, 2020 7:09 pm
Yes, I usually try to build things with future ease of maintenance in mind. The hinged gear leg fairings are definitely not in that category when I could just drill out 5 rivets like you. But, I personally think they are aesthetically the best option for a removable leg fairing.
PostPosted: Sun Jan 03, 2021 3:37 pm
My idea for the leg fairing . #40 screws and nutplates . You will never know there are nutplates attached to the back of the fairing (at least you can't see them ) . Feeble idea from a feeble mind ! ::)
PostPosted: Sun Jan 03, 2021 8:01 pm
I did what you see in RBs bird. Except I rivet in a piece of 1/8 by 3/4 aluminum. I simply tap that for the screws. The Tigress has the same thing except the trailing edge is folded so the strip is actually about an inch forward of the trailing edge.
PostPosted: Sun Jan 03, 2021 8:53 pm
I used folded trailing edges to match my flaps and ailerons. The picture is not great but I put the seam on the inside and just stuck the trailing edge of the inside into the folded part. Tension keeps it there, no fasteners. Just a connection at the top fairing to keep it from falling down.
PostPosted: Thu Jan 07, 2021 3:50 pm
David Read's idea and execution are brilliant!...I'd pay serious money for a template of that piece!! Kudos David!!
PostPosted: Thu Jan 14, 2021 2:59 pm
Guys,
I have the hinge on the trailing edge of the gear leg fairing as well. My solution was to replace the pin with a piece of 1/16" stainless steel welding rod. Sharpened to a point on the bottom and bent in an "L" shape on the top. It is bent into a curve and installs and removes easy. The 1/16 rod is smaller in diameter but it is not noticeable.
Regards,
PostPosted: Sat Jan 16, 2021 8:56 am
Is that seam like what is used on HVAC metal duct pipe?
PostPosted: Sun Jan 17, 2021 7:53 pm
Nope. The outside piece trailing edge is rolled around just like we do ailerons. In other words it has about a 1/4” diameter and the outside piece ends after traveling about 1/2-5/8” forward. The trailing edge of the inside piece is cut off square and just sets inside of the curled edge. I do not completely bend the leading edge so there is a little tension holding the trailing edges apart. This gives the sides their rounded shape. It makes the seam almost invisible and no fasteners needed. Mine has been like that for several hundred hour with no issues.
Users browsing this forum: No registered users and 20 guests
[ Time : 0.093s | 12 Queries | GZIP : On ]
