It is currently Sun Nov 02, 2025 10:01 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Fuel Leak From Belly
PostPosted: Fri Feb 15, 2019 11:57 pm
I just found a picture on-line of a Dukes fuel boost pump 4140-00-17, which looks like yours.
The threaded holes for the fittings have a 45 degree chamfered O ring seat. I'm thinking that the washer (not a gasket) is supposed to flatten the O ring until it seals from that seat to the un-threaded gap in your (modified) bulkhead fitting.
If that is going to work, I think you may need an O ring made from thicker cord. (just my perception from looking at your pics)
https://picclick.com/4140-00-17-Dukes-F ... 51830.html
These take AN to O ring adapters, check this link:
https://www.summitracing.com/search/dep ... ing&page=3
You have a home made version of the 90 degree variety. you can see them in the link. (also some unrelated power steering fittings etc)
These all have a smooth spot under the nut (no threads) for the O ring to seal when it is compressed into the chamfered space.
A pull from the product description:
ICT Billet AN to straight thread O-ring (ORB) adapter fittings connect AN threaded flexible hoses or rigid metal tubing to straight thread O-Ring Boss (ORB) fittings. ORB fittings are recommended for optimal leakage control in medium and high-pressure fluid systems. The seal takes place by compressing the O-ring; the threads hold the connection mechanically.
If you install the correct engineered part, it might last more than 100 hours. ;)
PostPosted: Sat Feb 16, 2019 9:33 am
x2
[ Time : 0.114s | 9 Queries | GZIP : On ]
