It is currently Sun Nov 02, 2025 10:08 am
flychris
 Post subject: Stall strips
PostPosted: Wed Apr 11, 2012 5:09 am
Where to get them and where exactly do they go on the inner wing?
Chris Cox
 Post subject: Re: Stall strips
PostPosted: Wed Apr 11, 2012 7:44 am
Chris,
Have a look at newsletter 71.
PostPosted: Wed Apr 11, 2012 7:47 am
Oops! Make that newsletter 82!
New2T18
PostPosted: Sun Nov 04, 2018 11:36 pm
New to the forum. Looking at purchasing a T18 and doing research on the stall strip. How do I find newsletter 82?
Thanks in advance
PostPosted: Mon Nov 05, 2018 6:47 am
Good question. They should be on the main website: http://thorp18.com/index.php?option=com ... Itemid=159
but they didn't come up. They were on the old forum with all of them scanned into 2 files but I can't seem to find the old forum anymore either.
NL82.pdf [1.18 MiB]
Downloaded 1701 times
New2T18
PostPosted: Mon Nov 05, 2018 12:38 pm
Thank you very much. Very interesting and I'm not sure what the negative could possibly be, or am I missing something. They sound very straight forward to install.
I assume these are made from solid stock and machined? Or could they be as simple as 3/8" x 3/8" aluminum angle for the material, granted the angle material would create a very small air gap between the leading edge, but is that even an issue? It seems they would mount pretty tight.
PostPosted: Mon Nov 05, 2018 1:51 pm
There is a sketch on the next page(5) of the news letter that implies solid stock by giving a 1/2" radius to match the leading edge.
PostPosted: Mon Nov 05, 2018 4:13 pm
Guys,
I made mine from 3/8" aluminum angle. I ground the edges so that there was virtually a sharp edge where they touched the leading edge. I stuck them on with a silicone adhesive. It was black and so is my plane so there was no appearance issues. I now have a stick shake just before the stall.
Regards,
[ Time : 0.266s | 10 Queries | GZIP : On ]
