It is currently Fri Oct 02, 2026 9:06 pm
Post new topic Reply to topic  [ 107 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: Aux Fuel Tank
PostPosted: Mon May 21, 2018 9:40 am
I ran WnB for two fuel tanks below the baggage compartment floor. It worked ok at 20 gallons. Of course, that was with a car engine up front.
PostPosted: Mon May 21, 2018 1:02 pm
Like I said before , if I had the chance I would put in the larger DR main tank ! ::)
Gary Green
PostPosted: Mon May 21, 2018 2:50 pm
Of all the solutions for increasing T-18 fuel capacity, I like David Read's. Forty Gallons is all I would ask for. If you need more than that, David's scheme won't work for you. But with the modern instrumentation available, a shallow instrument panel design can expand the space available in John Thorp's original design and adds the benefits of single tank, gravity feed, minimal CG impact, simple plumbing, etc.
GG
PostPosted: Mon May 21, 2018 3:07 pm
Exactly what I said !! :o
PostPosted: Wed May 23, 2018 10:06 pm
I submitted an engineering request for a fuel bladder in the outer wing panel as I mentioned.
We'll soon know how spendy and irresponsible it is... :P
T-18 Fuel Cell.pdf [1.4 MiB]
Downloaded 1588 times
PostPosted: Fri May 25, 2018 5:03 pm
Dave Dack @ ATL the fuel cell company got back to be today with a quote for the fuel tank(s).
Kinda spendy, about $600 per gallon!
Well, that's the first bid...maybe Race car or Boat....
Emery.pdf [542.97 KiB]
Downloaded 1270 times
PostPosted: Fri May 25, 2018 6:40 pm
If I didn't go the DR tank route , I would put in a single thin profile aluminum race tank on the baggage compartment floor . :P Single in tank pump to fill the main tank . ;) 15 + gallons ?
PostPosted: Fri May 25, 2018 10:05 pm
I hear you RB.
before I got on the fuel bladder idea, I'd been designing a con-formal wing tank to fit close under the wing join, similar to the Hunter 'non-drop' tank, but looking more like the engine pod of an Me-262.
I picked up some .063 5052 Aluminum sheet and some HTS-2000 aluminum 'welding' rod:
https://www.aluminumrepair.com/hts-2000 ... azing-rod/
Hoping to make a warp-free brazed external tank.
The baggage under-floor tank seems a lot easier, especially the plumbing.
Here is a cool Newton filler cap with angled neck for a side-of-the-fuselage filler
https://fuelsafe.com/a36nl44lfk-flush-c ... e-flapper/
This filler has a vent point that is above the tank, and being at the side of the fuselage, could loop up to the upper longeron like an RV, then through the floor to a pitot tip.
No Muss No Fuss. Could we also say Good To The Last Drop ?
PostPosted: Sat May 26, 2018 6:14 am
Scott,
if you install a tank below the level of the main tank be careful of fuel from the main tank traveling to your aux tank. Until the fuel is well below the point in the main tank where the aux fuel is introduced it will flow backwards. I have had this issue on two A/C I have owned (a Chief & a Thorp). Using a inline valve or check will solve the issue.
Phil
118BC
PostPosted: Sat May 26, 2018 5:54 pm
Phil has a good point. Spanky has an 8 gallon aux tank bolted to the under side of his turtle deck. We found that a full main will back fill that aux on the ground.
PostPosted: Sat May 26, 2018 11:09 pm
Cubes and All;
I'm wondering if the turtle-deck fuel tank can gravity feed the engine during (reasonable) level cruise flight?
That alone would have merit on a gravity feed ship.
fulcrumflyer
PostPosted: Sun May 27, 2018 8:19 am
SHIPCHIEF wrote:
Cubes and All;
Yes it can. It's been ops tested in my airplane (see Cubes' earlier post). The worst part of my tank set-up is that the filler cap is in the cockpit behind the passenger seat. That makes it difficult to get a fuel nozzle inside to fill up the tank. The last thing I want is a fuel spill in the cockpit.
SPANKY
PostPosted: Sun May 27, 2018 8:34 am
I would be interested in seeing fabrication and installation drawings, particularly how its secured to the turtle deck. I have often thought of putting extra fuel on the baggage area floor but that that would require a pump, whereas your turtle deck tank does not.
PostPosted: Mon May 28, 2018 6:31 am
I think the turtle-deck tank could be plumbed with an external filler neck just below the canopy without losing much capacity. A vented cap may leak when the tail came up for flight. The tank could possisbly be lowered a little bit but that may affect the gravity feed option. I would want a way to check the tank for water before flight which means a sump somewhere. Routing the fuel lines downhill for gravity feed could be a challenge.
PostPosted: Mon May 28, 2018 9:10 am
I think Spanky is going to take some pictures. If there is enough interest, I'll. Have some made. The easiest way to fill it is to measure how much you put in.
[ Time : 0.428s | 12 Queries | GZIP : On ]
