Jeff J wrote:
I would think 14 gauge wire is heavy enough but need to know how many amps the motor can draw and how long the wire is to verify gauge needed. You could be right about the switch if it wasn’t designed to carry the load.
This looks like the original motor from the build in the 70s but I can't see markings.  Next week I'll get pictures and see if there is a stamp somewhere.  It hasn't tripped the 5amp breaker so it has to be less than that
The slow trim is nice in flight but I struggle on take off.  If the trim isn't perfect I have to hold way too much forward pressure and it takes a good 30 seconds to level out.  My trim indicator is skipping teeth so it's not accurate and my landing trim is very tail heavy.  So rich and go landings don't have enough time to trim level.  I can hold the pressure but if I were to slip or something happen I think there is potential for a safety hazard.  It doesn't feel unsafe but I don't like any potential.
It might all balance out once I remove as all my bad stuff as and change lighter avionics as planned here in a few months though.  I was just hoping for more like 15 seconds trim travel and not 30+
